Connectcore Imx6UL Micro AB OTG enable
860 次查看
nagarjun_cs90
I am new to DIGI community, I want to enable OTG support on the micro AB in CC IMX6UL SBC Express. I have used the following setup in order to enable OTG for the Micro AB:
&usbotg1 {
dr_mode = "otg";
fsl,power-line-polarity-active-high;
disable-over-current;
status = "okay";
&usbotg2 {
dr_mode = "host";
status = "okay";
But, Unfortunately I am not able to enable OTG on the micro USB. When I try drmode = "otg" @usbotg1, USB1 in host turns off and no longer detects USB.
Kindly, let me know for any suggestions.
Thank you.
标签 (2)
标记 (3)
760 次查看
igorpadykov
Hi Nagarjun
digi community is on link
Recent activity - Digi Forum
For usb usage one can look at
USB Host/On-The-Go
and attached Linux Manual Chapter 39 CHIPIDEA USB Driver
760 次查看
nagarjun_cs90
Hi Igor,
I had gone through the link and tried it. USB host itself gets disabled. So, its not working. Is there an other way?
