As per our project requirement, currently we are using iMX8MM EVK and there is a need to verify if the below mentioned code exists for both WiFi+BT(AW-CM358MA) on EVK :
Is there a provision to dynamically change the above parameters for testing purpose.
Hrithik
Solved! Go to Solution.
Hi Hrithik
for changing parameters one can look at sect.2.8 RF test mode UM11490 Feature Configuration Guide for NXP-based Wireless Modules on i.MX 8M Quad EVK - User manual (public...
Linux driver capabilities can be found in NXP Wi-Fi Driver Features and Release Notes
Thanks for the documents@igorpadykov !
Hi Hrithik
