Cannot find libboost_numpy in imx8mq yocto build
nishitha_a
I need to get libboost_numpy library in the yocto image.
So I added the following lines in local.conf file
PACKAGECONFIG_pn-boost = "python"
IMAGE_INSTALL_append+="python3-numpy"
Then
bitbake imx-image-multimedia
bitbake imx-image-multimedia -c populate_sdk
But the library is not generated. What can be the issue ?
weidong_sun
Hello nishitha_a ,
Below is my advice:
1. Add "BBCLASSEXTEND = "native nativesdk"" to the end of related .bb file.
This can add library to SDK.
2. Add library to rootfs
the command can add library to rootfs.
You can try it, again.
If it can't reach your purpose, You can refer to the relevant materials of Yocto.
Have a nice day!
B.R,
Weidong
nishitha_a
The specified line is already there in the python-numpy.inc file
