Cannot boot on SD when SD is present on mmc0 slot
4,276 次查看
francoisrey
I try to boot Linux version 3.0.35-ts-armv7l with U-Boot 2013.07.
If I put the sd (with linux image and rfs) on mmc0 slot, linux boot crash with the error "VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1)". If I put the sd on mmc1 slot it works.
I can see that linux detect the mmc0 before trying to open root device, but not mmc1.
Here is the console files of each configuration.
Have you a solution to boot on a SD on mmc0 slot ?
Original Attachment has been moved to: mmc0.txt.zip
Original Attachment has been moved to: mmc1.txt.zip
标签 (3)
6 回复数
2,357 次查看
edison_fernande
Hi francoisrey,
When your board is booting you should see something like this in the boot log:
mmc1: new high speed SDHC card at address b368
mmcblk0: mmc1:b368 3.73 GiB
mmcblk0: p1 p2
In this case, it is a SD card with 2 partitions, in my case, with the rootfs in p2 (mmcblk0p2)  so the bootargs fort this specific case should looks like:
root=/dev/mmcblk0p2
In your case you should:
1. Put your SD wherever you want to boot from.
2. Take a look at the boot log to see the appropriate device.
3. Reboot and stop at u-boot and edit your bootargs to match your device.
something like:
     editenv bootargs
4. boot with the new bootargs.
     bootm
Hope this helps.
Edison
2,357 次查看
francoisrey
I see that :
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD08G 7.42 GiB (ro)
mmcblk0: p1
I have the rootfs in the partition 1
My bootargs containts that :
root=/dev/mmcblk0p1
but the error is that :
Please append a correct "root=" boot option; here are the available partitions:
If I put the sd in slot mmc1 it works with the same arg and I can see that when it boot.
mmc1: new high speed SDHC card at address 0007
mmcblk0: mmc1:0007 SD08G 7.42 GiB
mmcblk0: p1
2,357 次查看
edison_fernande
It seems like something is wrong either with your hardware or with your software. To discard your hardware could you try this image:
http://www.ridgerun.com/demos/imx6-boundary-devices-nitrogen6x-demo/imx6-boundary-devices-nitrogen6x...
It basically uses kernel version 3.0.35-4.0.0 from Boundary devices.
The kernel image is going to be in partition 0 and the rootfs in partition 2 so you should use something like "root=/dev/mmcblk0p2" in order to boot. If with this image you are getting the same results something is wrong with your hardware, if it works it is something in your software.
Let me know if this helps.
Edison
2,357 次查看
francoisrey
Thanks for your reply,
it seems to be an hardware bug.
But I don't understand which one, because when I boot on mmc 1 it works and I can read and write data on mmc 0 without problems.
2,357 次查看
alejandrolozan1
Have you tried to play with the bootargs?
For Example:
mmc dev 0
Alejandro
2,357 次查看
francoisrey
I tried to play with the bootargs : root=/dev/mmcblk0p1
if there is a SD in slot mmc 0 the first partition of this SD take the address /dev/mmcblk0p1, and the first partition of the SD in slot mmc 1 take the address /dev/mmcblk1p1.
if there is no  SD in slot mmc 0, the first partition of the SD in slot mmc 1 take the address /dev/mmcblk0p1.
