Can't see saved file after reboot in /data file system.
973件の閲覧回数
eddiehuang
Recently I tried to save a file in /data file system, for instance, "echo 1 > /data/a.txt" and reboot. I cannot see this file after reboot, why is that? Thank you.
4 返答(返信)
889件の閲覧回数
christophertele
i had the same problem. files created with "touch" are deletd during boot (from SD). the only thing that works is using "vi" to create, read and write files on the SD-card. Nano can read but isnt able to safe your changes.
cheers
Christopher
889件の閲覧回数
b36401
I suppose the file can be cached and its update can be delayed a bit and then lost with sudden reboot.
So I can provide a common suggestion. Please try to perform "sync" before reboot.
By the way. What filesystem is used for /data ?
Is it located on some separate partition or device?
Victor
889件の閲覧回数
eddiehuang
Thanks for your reply. ext4 file system is used for /data and this happens when the board is booting with SD card while the creation of a file could be kept with eMMC booting. I'm new to this field and I cannot figure out why there's such a difference existing in various booting ways.
889件の閲覧回数
b36401
I have no idea too why it depends on booting source.
Please try to run "sync" and check if it helps.
Victor
