I'm not able to play video on android 4.4.2 on imx6q board, although I'm able to play video with the command line in h264 raw format "mxc-vpu-test -D "-i /clip.raw.h264 -f2"
If I try to open a video with the android Video player (h264 or mpeg4 codec encapsulated in mp4), it says "can't play this video".
the logcat shows some errors. Here's the most relevant:
E/BufferQueue( 2230): [com.android.gallery3d/com.android.gallery3d.app.MovieActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
I/ActivityManager( 2978): Displayed com.android.gallery3d/.app.MovieActivity: +226ms
E/MediaPlayer( 3731): error (1, -2147483648)
E/MediaPlayer( 3731): Error (1,-2147483648)
D/VideoView( 3731): Error: 1,-2147483648
D/dalvikvm( 3731): GC_FOR_ALLOC freed 832K, 23% free 3174K/4084K, paused 16ms, total 16ms
Installing the CactusPlayer by reverting the relevant patch does not help as well.
解決済! 解決策の投稿を見る。
I solved the issue. The files media_codecs.xml and media_profiles.xml were not installed.
Can you try to disable OMX framework and enable the stagefright?
setprop media.omxgm.enable-player 0
Saurabh
It does not help. I still cannot play video.
Also the error in log does not seems to change.
Oussama
In the imx6qd.mk I have the following include:
-include external/fsl_vpu_omx/codec_env.mk (Initialize HAVE_FSL_IMX_CODEC to false)
-include external/fsl_imx_omx/codec_env.mk (Does not exist!)
Is this is normal?
Can you check Audio content of the video file?
Saurabh
What to check exactly? otherwise here's some info.
The audio coded is "MPEG-4 AAC audio" sampled at 44100 HZ.
For the moment i do not expect the audio to work properly. and here's full log that contains audio error:
I/ActivityManager( 2978): START u0 {act=android.intent.action.VIEW dat=file:///Wildlife_512kb.mp4 typ=video/mp4 flg=0x4000000 cmp=com.android.gallery3d/.app.MovieActivity (has extras)} from pid 3583
E/AudioCache( 2233): Error 1, -2147483648 occurred
E/SoundPool( 2978): Unable to load sample: (null)
W/AudioService( 2978): onLoadSoundEffects(), Error -22 while loading samples
E/CacheManager( 3731): Cannot instantiate cache!
E/CacheManager( 3731): java.io.FileNotFoundException: /storage/emulated/0/Android/data/com.android.gallery3d/cache/bookmark.idx: open failed: EACCES (Permission denied)
E/CacheManager( 3731): at libcore.io.IoBridge.open(IoBridge.java:409)
E/CacheManager( 3731): at java.io.RandomAccessFile.<init>(RandomAccessFile.java:118)
E/CacheManager( 3731): at java.io.RandomAccessFile.<init>(RandomAccessFile.java:150)
E/CacheManager( 3731): at com.android.gallery3d.common.BlobCache.<init>(BlobCache.java:140)
E/CacheManager( 3731): at com.android.gallery3d.util.CacheManager.getCache(CacheManager.java:51)
E/CacheManager( 3731): at com.android.gallery3d.app.Bookmarker.getBookmark(MoviePlayer.java:518)
E/CacheManager( 3731): at com.android.gallery3d.app.MoviePlayer.<init>(MoviePlayer.java:196)
E/CacheManager( 3731): at com.android.gallery3d.app.MovieActivity$1.<init>(MovieActivity.java:92)
E/CacheManager( 3731): at com.android.gallery3d.app.MovieActivity.onCreate(MovieActivity.java:91)
E/CacheManager( 3731): at android.app.Activity.performCreate(Activity.java:5231)
E/CacheManager( 3731): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
E/CacheManager( 3731): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2159)
E/CacheManager( 3731): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2245)
E/CacheManager( 3731): at android.app.ActivityThread.access$800(ActivityThread.java:135)
E/CacheManager( 3731): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
E/CacheManager( 3731): at android.os.Handler.dispatchMessage(Handler.java:102)
E/CacheManager( 3731): at android.os.Looper.loop(Looper.java:136)
E/CacheManager( 3731): at android.app.ActivityThread.main(ActivityThread.java:5017)
E/CacheManager( 3731): at java.lang.reflect.Method.invokeNative(Native Method)
E/CacheManager( 3731): at java.lang.reflect.Method.invoke(Method.java:515)
E/CacheManager( 3731): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
E/CacheManager( 3731): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
E/CacheManager( 3731): at dalvik.system.NativeStart.main(Native Method)
E/CacheManager( 3731): Caused by: libcore.io.ErrnoException: open failed: EACCES (Permission denied)
E/CacheManager( 3731): at libcore.io.Posix.open(Native Method)
E/CacheManager( 3731): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:110)
E/CacheManager( 3731): at libcore.io.IoBridge.open(IoBridge.java:393)
E/CacheManager( 3731): ... 22 more
W/Bookmarker( 3731): getBookmark failed
W/Bookmarker( 3731): java.lang.NullPointerException
W/Bookmarker( 3731): at com.android.gallery3d.app.Bookmarker.getBookmark(MoviePlayer.java:522)
W/Bookmarker( 3731): at com.android.gallery3d.app.MoviePlayer.<init>(MoviePlayer.java:196)
W/Bookmarker( 3731): at com.android.gallery3d.app.MovieActivity$1.<init>(MovieActivity.java:92)
W/Bookmarker( 3731): at com.android.gallery3d.app.MovieActivity.onCreate(MovieActivity.java:91)
W/Bookmarker( 3731): at android.app.Activity.performCreate(Activity.java:5231)
W/Bookmarker( 3731): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1087)
W/Bookmarker( 3731): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2159)
W/Bookmarker( 3731): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2245)
W/Bookmarker( 3731): at android.app.ActivityThread.access$800(ActivityThread.java:135)
W/Bookmarker( 3731): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
W/Bookmarker( 3731): at android.os.Handler.dispatchMessage(Handler.java:102)
W/Bookmarker( 3731): at android.os.Looper.loop(Looper.java:136)
W/Bookmarker( 3731): at android.app.ActivityThread.main(ActivityThread.java:5017)
W/Bookmarker( 3731): at java.lang.reflect.Method.invokeNative(Native Method)
W/Bookmarker( 3731): at java.lang.reflect.Method.invoke(Method.java:515)
W/Bookmarker( 3731): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
W/Bookmarker( 3731): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
W/Bookmarker( 3731): at dalvik.system.NativeStart.main(Native Method)
I/MediaFocusControl( 2978): AudioFocus requestAudioFocus() from android.media.AudioManager@2c539358
Oussama
If audio failed than video playback is also failed in OMXFrameworks.
I suggest please try video only file.
Video only file does not work too. however I'm still getting the audio error even there is no audio in the file
I get permission error from android when I try to open a file from the browser.
W/ServiceManager( 2348): Permission failure: android.permission.INTERNET from uid=10034 pid=3809
E/MediaPlayerService( 2348): Request requires android.permission.INTERNET
E/MediaPlayer( 3809): Unable to create media player
W/Cactus ( 3809): Unable to open content: http://192.168.1.10:8000/video_only.mp4
I fixed the permission error by adding the requested permission in AndroidManifest.xml file and recompile the app.
But then I got the following error:
D/Cactus (14747): VideoPlayer: onCreate
D/Cactus (14747): VideoPlayer: parseIntent
D/Cactus (14747): VideoPlayer: onStart
D/Cactus (14747): VideoPlayer: onResume
D/CactusPlayer(14747): onMeasure mVideoW 0 mVideoH 0 widthMesaureSpec 1073742582 heightMeasureSpec 1073742239
D/libEGL (14747): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL (14747): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL (14747): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue(12622): [com.freescale.cactusplayer/com.freescale.cactusplayer.VideoPlayer] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/OpenGLRenderer(14747): Enabling debug mode 0
D/Cactus (14747): surfaceCreated
I/AwesomePlayer(12626): setDataSource_l(URL suppressed)
W/Cactus (14747): Url is http://192.168.1.10:8000/video_only.mp4
D/AndroidRuntime(14747): Shutting down VM
W/dalvikvm(14747): threadid=1: thread exiting with uncaught exception (group=0x2caf2ba8)
E/AndroidRuntime(14747): FATAL EXCEPTION: main
E/AndroidRuntime(14747): Process: com.freescale.cactusplayer, PID: 14747
E/AndroidRuntime(14747): java.lang.NullPointerException
E/AndroidRuntime(14747): at com.freescale.cactusplayer.VideoPlayer.play(VideoPlayer.java:697)
E/AndroidRuntime(14747): at com.freescale.cactusplayer.VideoPlayer.surfaceCreated(VideoPlayer.java:1061)
E/AndroidRuntime(14747): at android.view.SurfaceView.updateWindow(SurfaceView.java:572)
E/AndroidRuntime(14747): at android.view.SurfaceView.access$000(SurfaceView.java:86)
E/AndroidRuntime(14747): at android.view.SurfaceView$3.onPreDraw(SurfaceView.java:175)
E/AndroidRuntime(14747): at android.view.ViewTreeObserver.dispatchOnPreDraw(ViewTreeObserver.java:847)
E/AndroidRuntime(14747): at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:1871)
E/AndroidRuntime(14747): at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1000)
E/AndroidRuntime(14747): at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:5670)
E/AndroidRuntime(14747): at android.view.Choreographer$CallbackRecord.run(Choreographer.java:761)
E/AndroidRuntime(14747): at android.view.Choreographer.doCallbacks(Choreographer.java:574)
E/AndroidRuntime(14747): at android.view.Choreographer.doFrame(Choreographer.java:544)
E/AndroidRuntime(14747): at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:747)
E/AndroidRuntime(14747): at android.os.Handler.handleCallback(Handler.java:733)
E/AndroidRuntime(14747): at android.os.Handler.dispatchMessage(Handler.java:95)
E/AndroidRuntime(14747): at android.os.Looper.loop(Looper.java:136)
E/AndroidRuntime(14747): at android.app.ActivityThread.main(ActivityThread.java:5017)
E/AndroidRuntime(14747): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime(14747): at java.lang.reflect.Method.invoke(Method.java:515)
E/AndroidRuntime(14747): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:779)
E/AndroidRuntime(14747): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:595)
E/AndroidRuntime(14747): at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager(13337): Force finishing activity com.freescale.cactusplayer/.VideoPlayer
D/dalvikvm(14747): GC_CONCURRENT freed 110K, 6% free 3007K/3192K, paused 2ms+2ms, total 19ms
W/ActivityManager(13337): Activity pause timeout for ActivityRecord{2d0c27f8 u0 com.freescale.cactusplayer/.VideoPlayer t2 f}
D/WebViewTimersControl(14027): onBrowserActivityResume
D/WebViewTimersControl(14027): Resuming webview timers, view=com.android.browser.BrowserWebView{2cddc878 VFEDHVCL .F...... 0,0-758,403}
E/BufferQueue(12622): [com.android.browser/com.android.browser.BrowserActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/dalvikvm(14027): GC_CONCURRENT freed 391K, 11% free 4248K/4768K, paused 3ms+4ms, total 25ms
I do not see VPU log... I'm not sure if this normal?
