Can I use buffer allocated by g2d_alloc() in V4L2 capture?
2,489 次查看
dustinzhu
In order to save copy time between capture buffer and fb device buffer, we try to use g2d_alloc() to get buffer which transfers into V4L2 driver with V4L2_MEMORY_USERPTR.
I wanna know whether it is right in the process.
标签 (3)
1 回复
2,356 次查看
Hi Dustin
seems it is not good approach as graphics are handled by gpu drivers
described in sect.5.1 Graphics Processing Unit (GPU) and they are different
from V4L2 drivers, described in sect.6.1.2.1.2.1 Video for Linux 2 (V4L2) APIs
