I am trying to output the clock of CCM_CLKO2 from GPIO_SD_B0_05 on i.MXRT1064.
I set pins and clocks in MCUXpresso Config Tool and implemented them, but I cannot observe the clocks from the pins.
Do I need to set anything other than the following?
pin_mux.c
clock_config.c
Any help is appreciated, thanks.
T.Y.
解決済! 解決策の投稿を見る。
Hi T. Y.,
Could you please tell me which detail clock you want to output in CCM_CLKO2 from GPIO_SD_B0_05?
I find your code is choose the sai1_clk_root.
Do you already enable the related clock?
Please tell me which detail code you want to output, then I will also help you to test it.
Kerry
Hi T. Y.,
Kerry
Thanks, your guide. Really helped me.
Relevant clock was not enabled.
Waveform output came as expected;
Thanks.
Hi riley mahi,
Perfect! I am glad to hear you make it works now.
If you have any questions in the future, welcome to create the question post, thanks!
Kerry
Hi kerryzhou,
Thank you for helping me,
That is correct.
Did not enable the relevant clock.
Waveform came out as desired!
T.Y.
