I'm making new design with i.MX7D.
In my design, I do not use LCD1. So, I only connect to PU/PD resitors to configure boot at SDcard(SD1) or 8bit eMMC (SD3)
SDCard BOOT_CFG[15:12] = 0001; BOOT_CFG[11:10] = 00; BOOT_CFG[6:4] = 001
eMMC BOOT_CFG[15:12] = 0010; BOOT_CFG[11:10] = 10; BOOT_CFG[6:4] = 010
I want to reduce number of resitors as few as possible,
External PU/PD resistor at only pin LCD1_DATA: 13 12 11 5 4, and other LCD1_DATA are floating
Is this solution ok?
Thanks and best regards,
Dinh Huy
Hi Dinh
if boot configs is verified, yes such solution also can be used.
Actually at reset LCD1_DATA are 100K Pull Downed according to
Table 96. Fuses and associated pins used for boot i.MX7D Datasheet
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX7DCEC.pdf
