Bitbake options
1,483件の閲覧回数
chandraevolute
Contributor V
what is the difference between bitbake -c compile -f linu-imx and bitbake linu-imx
whenI run bitbake -c compile -f linu-imx this command it executed succesfully but when I try to do bitbake linu-imx it fails
927件の閲覧回数
Yuri
  Please look at the following
Useful bitbake commands
Yuri
4 返答(返信)
927件の閲覧回数
chandraevolute
Contributor V
I tried to run core-image-minimal and it is running 3.14.28 version  instead if 3.14.38...the 3.14.28 does not support for 3.14.38
928件の閲覧回数
Yuri
Yuri
927件の閲覧回数
chandraevolute
Contributor V
Thank you YuriMuhin_ng got the difference...
one more issue is when I do bitbake fsl-image-gui the .sdcard image is showing 880MB size. How can I reduce the rootfs. where as my zImage is 4MB only.
927件の閲覧回数
Yuri
  the .sdcard image includes U-boot, kernel and file system.
It  requires to remove non-needed packages in order to reduce file system.
Perhaps it would be better to use core-image-minimal configuration.
Yuri.
