We have got a customized board which has been designed based Wandboard -dual.
While porting the BSP we are follwoinf the Yocto project's "BSP porting guide.pdf" according to which we have done the following steps:
1. We came to know that working directory for uboot is:
/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git
2. We have prepared the code for uboot by
2.1 Copy the board directory, as shown below:
$cp -R board/wandboard board/wandboard_dual_lpddr2
2.2 copy the existing configuration file (.h file) for the custom board
$cp include/configs/wandboard.h include/configs/wandboard_dual_lpddr2.h
2.3 Create one entry in <UBOOT_DIR>/boards.cfg for the new -based configuration.
We have created following entry :
Active arm | armv7 | mx6 | - | wandboard | wandboard_dual_lpddr2 |
wandboard:IMX_CONFIG=board/wandboard_dual_lpddr2/wandboard_dual_lpddr2.cfg,MX6DL,DDR_MB=1024 |
2.4 Renamed the file /board/wandboard_dual_lpddr2/wandboard.c to /board/wandboard_dual_lpddr2/wandboard_dual_lpddr2.c
2.5 Changed the line
COBJS:= wandboard.o to
obj-y := wandboard_dual_lpddr2.o
3. Created a shell script under <UBOOT_DIR> named build_u-boot.sh.
The file contents are as follows:
#!/bin/bash
export ARCH=arm
export CROSS_COMPILE=/home/srinivas/fsl-community-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/cortexa9hf-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-
make distclean;
make wandboard_dual_lpddr2_config
make
4. Compiled U-Boot by using $bash ./build_u-boot.sh which is giving so many errors
the errors are as follows:
/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git/include/configs/wandboard_dual_lpddr2.h:115:13: error: expected '}' before 'CONFIG_DEFAULT_FDT_FILE'
"fdt_file="CONFIG_DEFAULT_FDT_FILE"\0" \
/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git/include/env_default.h:122:2: note: in expansion of macro 'CONFIG_EXTRA_ENV_SETTINGS'
make[1]: *** [env_common.o] Error 1
make[1]: Leaving directory `/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git/common'
make: *** [common/libcommon.o] Error 2
So after going through errors i have modified the /git/include/configs/wandboard_dual_lpddr2.h where "fdt_file="CONFIG_DEFAULT_FDT_FILE"\0" \ is been changed to "fdt_file=CONFIG_DEFAULT_FDT_FILE\0" \ the same way same variable is changed in /git/board/wandboard_dual_lpddr2/wandboard_dual_lpddr2.cfg
now when i run the command for compiling uboot: $bash ./build_u-boot.sh following errors are coming
/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git/include/asm/arch/mx6-pins.h:18:2: error: #error "Please select cpu"
make[1]: *** No rule to make target `.depend', needed by `libwandboard.o'. Stop.
make[1]: Leaving directory `/home/srinivas/fsl-community-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-fslc/v2013.10-r0/git/board/wandboard'
make: *** [board/wandboard/libwandboard.o] Error 2
what is problem. Why uboot is not compiling. after compilation only, we can customize it. how to resolve this issue.
Original Attachment has been moved to: wandboard_dual_lpddr2.cfg.zip
Original Attachment has been moved to: wandboard_dual_lpddr2.h.zip
Original Attachment has been moved to: mx6-pins.h.zip
Please try the next configuration:
Active arm | armv7 | mx6 | - | wandboard_dual_lpddr2 | wandboard_dual_lpddr2 |
Alejandro
after trying your suggestions also, we have got the following errors:
arch/arm/imx-common/built-in.o: In function `arch_preboot_os':
/home/srinivas/fsl-release-bsp/build/tmp/work/wandboard_dual-poky-linux-gnueabi/u-boot-imx/2014.04-r0/git/arch/arm/imx-common/cpu.c:203: undefined reference to `ldo_mode_set'
/home/srinivas/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/cortexa9hf-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: BFD (GNU Binutils) 2.24 assertion fail /home/srinivas/fsl-release-bsp/build/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/binutils-cross/2.24-r0/binutils-2.24/bfd/elf32-arm.c:7696
/home/srinivas/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/cortexa9hf-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: error: required section '.rel.plt' not found in the linker script
/home/srinivas/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/cortexa9hf-vfp-neon-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: final link failed: Invalid operation
make: *** [u-boot] Error 1
Did you try to build the original target reference first?
Please try that first and make sure do not moidfy the functionality of the code when porting U-boot first. Just make sure that you are including the correct .h files in the .c ones.
/Alejnadro
