Hi Everyone,
i am building yocto bsp for imx7dsabresd board using attached yocto user Guide , in bitbake i am getting following error, can any one help me how to resolve this error,
ERROR: vlan-1.9-r0 do_fetch: Fetcher failure for URL: 'http://vlan.sourcearchive.com/downloads/1.9-3ubuntu9/vlan_1.9.orig.tar.gz'. Unable to fetch URL from any source.
ERROR: vlan-1.9-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/linux-pc/imx-yocto-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/vlan/1.9-r0/temp/log.do_fetch.17006
ERROR: Task (/home/linux-pc/imx-yocto-bsp/sources/meta-openembedded/meta-networking/recipes-connectivity/vlan/vlan_1.9.bb:do_fetch) failed with exit code '1'
Thanks&Regards,
Prasad.
Solved! Go to Solution.
I also faced similar vlan fetch error recently, it seems the source link at vlan recipe is down(probably temporarily).
just switching to other healthy vlan v1.9 source link passed the vlan fetch error.
SRC_URI = "https://launchpad.net/ubuntu/+archive/primary/+sourcefiles/${BPN}/${PV}-3ubuntu10.1/${BPN}_${PV}.orig.tar.gz \
instead of SRC_URI = "http://${BPN}.sourcearchive.com/downloads/${PV}-3ubuntu9/${BPN}_${PV}.orig.tar.gz \
at sources/meta-openembedded/meta-networking/recipes-connectivity/vlan/vlan_1.9.bb
Shrikant
Shrikant
Thanks. Also worked for me!
Hi Shrikant,
Thanks For your support,it's worked for me also.
Thanks&Regards,
Prasad.
Hi Prasad,
Welcome, Thanks !
Shrikant
