Android SGTL5000 Audio codec setting
1,500件の閲覧回数
ispark
I uses KitKat 4.4.2. i.mx6SL.
default Audio codec configuration can't use HP output.
so I use below setting to command shell.
tinymix 25 on
tinymix 4 127
Then I want to add above command to initialization table init.freescale.rc but no effect.
So question is where should I add user command?
3 返答(返信)
924件の閲覧回数
ispark
Thanks. I added to original init.rc  and now works.
924件の閲覧回数
jimmychan
you may take hardware/imx/alsa/config_wm8962.h and tinyalsa_hal.c for reference.
924件の閲覧回数
gary_bisson
Senior Contributor III
Why don't you modify the audio HAL instead to set those values for you. This is the proper to set such setting.
Gary
