Android JB not wakeup
1,467 次查看
chenhoa
Hi all, I am now porting the Android JB to our customize board using IMX6Q, but it's stop here:
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1)
Freeing init memory: 240K
init: no such service 'bootanim'
ERROR: v4l2 capture: slave not found!
UV
ERROR: HDMI is not ready!
asoc: can't open platform imx-hdmi-soc-audio.0
warning: `zygote' uses 32-bit capabilities (legacy support in use)
request_suspend_state: wakeup (3->0) at 64456929342 (1970-01-02 00:00:02.115283333 UTC)
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
acc_open
acc_release
ehci_fsl_bus_resume begins, DR
mtp_open
request_suspend_state: sleep (0->3) at 78490105010 (1970-01-02 00:00:16.148458668 UTC)
UV
  UV
    US 921600
I have try with uart or rtc wakeup, but the it still sleep:
echo enabled > /sys/devices/platform/imx-uart.2/tty/ttymxc2/power/wakeup
echo +3 > /sys/class/rtc/rtc0/wakealarm
So, how can I wakeup my Android JB?
标签 (2)
4 回复数
850 次查看
AnsonHuang
Hi, chen
     Can you measure the PMIC_STBY_REQ pin on the board, better to monitor it from RUN mode->Sleep->wakeup, the level should be low->high->low. If it is high when it is not waking up, that means system still in sleep mode, the wakeup source on your board did NOT work. Please measure this signal first.
850 次查看
Rita_Wang
Hi chen,
The board is designed by customs, and which BSP are you use? Would you please attach the whole log file?
Best Regards
Dan
850 次查看
chenhoa
Hi Dan,
Thanks for your reply.
Sorry about my late reply. I just used BSP from Freescale with some modifications to test. I attached the log file
Best regards.
850 次查看
Rita_Wang
Hi chen,
I wonder if your problem have solved. If not, which version android BSP are you using? And what have you modified? From the information you gave, it's hard to detect where the problem is?
Best Regards
Dan
