Adding serial support to Qt4.6.0
668件の閲覧回数
nishad_kamdar
I have a custom iMX6q board and i am using Ltib with L3.0.35_4.1.0 Kernel.
I have installed QT version 4.6.0 and i am successfully able to run simple applications.
However, i specifically need serial connectivity support for my application.
As 4.6.0 does not by default have serial driver support , it would be very helpful if you could suggest the procedure to add serial connectivity support to the QT 4.6.0.
regards,
nishad
ラベル(2)
543件の閲覧回数
jimmychan
544件の閲覧回数
jimmychan
This may useful for you.
< QtSerialPort | Qt Wiki | Qt Project >
