Dear Sir or Madam,
Hello.
I have a question about fsl_ep_queue() of arcotg_udc.c in i.MX6SDL jb4.2.2_1.1.0.
[Issue]
See attached file : Issue Sequence.docx
[Test result]
Specifies 16 KB in req->length : No problem
Specifies 32 KB in req->length : The issue occured
Specifies 64 KB in req->length : The issue occured
[Question]
Is there limitation on the 16 KB upper limit in the argument req->length of fsl_ep_queue()?
Keita
已解决! 转到解答。
I apologize for nor being more concise on my answer.
The first case is right. 16Kbytes is the maximum transfer regardless of starting buffer alignment. That’s why it’s the recommended maximum.
Dear gusarambula,
Let me clarify your answer.
Which case is right?
[Case.1]
- 16KBytes is the upper limit which it is possible to set.
- When setting the value which is bigger than 16KB, the problem occurs.
[Case.2]
- You recommends to set the value which is smaller than 16KB.
- But freescale has never confirmed operation, when setting the value which is bigger than 16KB.
[Case.3]
- When setting the value which is bigger than 16KB, there is not a problem in case of operation.
But, it isn't possible to expect the improvement of the performance.
( Because the upper limit of end point transfer descriptor is 16KBytes )
[Case.4]
Is your answer the other meaning?
Keita
