About ECC function of NAND controller in i.MX515.
1,034件の閲覧回数
keitanagashima
Senior Contributor I
Dear Sir or Madam,
Hello.
I have a question about ECC function of NAND controller in i.MX515.
[Problem]
The ECC error occurred with two boards of my customer.
It is judged READ_SECTOR_ECC_ERROR because of ECC_STATUS_RESULT = 0x0f000ff0.
Refer to 45.7.15 ECC Status and Result of Flash Operation (ECC_STATUS_RESULT) in i.MX51RM(Rev.1).
[Question]
Is the value of ECC_STATUS_RESULT(= 0x0f000ff0) correct?
(i.e. Is the ECC function of NAND controller working right?)
I send the page which was made from NAND controller.
See attached fileh: PJ_001.bin & PJ_001.txt(hexdump)
The number of NAND FLASH which becames an error was 0x6900.
Could you check and calculate this page whether or not the ECC feature is correct.
[Environment]
- Board: Custom board
- OS: WCE600
- NAND: Toshiba 8Gbit TC58DVG3S0ETA00
-Detail of NAND Flash
  #define NAND_BLOCK_CNT          (4096)      // 4096 blocks
  #define NAND_PAGE_CNT           (64)        // Each Block has 64 Pages
  #define NAND_PAGE_SIZE          (4096)      // Each Page has 4096 Bytes
  #define NAND_SPARE_SIZE         (128)       // Each Page has 128 Bytes spare space
  #define NAND_BUS_WIDTH          (8)         // 8-bit bus
PS,
NAND Flash maker said; NAND Flash itself is no-problem by their reserchment.
29-Aug-2014
Keita
Original Attachment has been moved to: PJ_001.txt.zip
Original Attachment has been moved to: PJ_001.bin.zip
ラベル(2)
745件の閲覧回数
igorpadykov
Hi Keita
if this happens on one or two boards, then probably
these particular NANDs are broken and one can replace them
with new ones.
I am not sure that it is possible to judge on validity of ECC
based on NAND data, since algorithm which uses processor is quite
complex.
chip
746件の閲覧回数
igorpadykov
Hi Keita
with new ones.
complex.
chip
