Hi All,
Could you tell me a "BGA PAD MASK SIZE" in i.MX6DQ?
Please refer to attached detail file.
Keita
Solved! Go to Solution.
Hi Keita,
For the 0.8mm ball pitch PBGA package (as for the i.MX6Dual/Quad processors) the package-side pad mask opening diameter is equal to the pad diameter and equal to 0.4mm.
Artur
Hi Keita,
Artur
Hi Artur,
Thank you very much!
Keita
