ADV7180 on I.MX 6Solox Device Tree bindings
2,286 次查看
mirkoardinghi1
Hi, I would like to connect an adv7180 to my solox.
I found only example with ipu but in the 6SoloX ipu is not present.
Where can I find an example?
5 回复数
1,120 次查看
igorpadykov
Hi Mirko
one can reuse ov5640 dts, it also work in CCIR656 mode
linux-2.6-imx.git - Freescale i.MX Linux Tree
1,120 次查看
mirkoardinghi1
I have modify my dts and after boot I have the following devices:
/dev/video0
/dev/video1
/dev/video2
Unfortunately  when I try the command:
gst-launch-1.0 -v v4l2src do-timestamp=true device=/dev/video0  ! avimux ! filesink location=test.avi
or
gst-launch-1.0 -v v4l2src do-timestamp=true device=/dev/video1 ! avimux ! filesink location=test.avi
I have the following error (/dev/video2 is not a capture device) :
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstAviMux:avimux0.GstPad:src: caps = video/x-msvideo
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/x-msvideo
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data flow error.
Additional debug info:
/home/user/yocto/fido/imx6sx/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/gstreamer1.0/1.4.5-r0/gstreamer-1.4.5/libs/gst/base/gstbasesrc.c(2933): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2s:
streaming task paused, reason not-negotiated (-4)
Execution ended after 0:00:00.003625333
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
and if I use mplayer
./mplayer tv:// -tv driver=v4l2:device=/dev/video[0-1]
I have the following error:
MPlayer UNKNOWN-4.9.2 (C) 2000-20unknown pixelformat:'     '
16 MPlayer Team
Playing tv://.mx6s-csi 221c000.csi: Fourcc format (0x00000000) invalid.
TV file format detected.
Selected driver: v4l2
name: Video 4 Linux 2 input
author: Martin Olschewski <olschewski@zpr.uni-koeln.de>
comment: first try, more to come ;-)
Selected device: i.MX6S_CSI
Capabilities:  video capture  streaming
supported norms:
inputs: 0 = Camera;
Current input: 0
Current format: unknown (0x0)
v4l2: ioctl set format failed: Invalid argument
v4l2: ioctl set mute failed: Inappropriate ioctl for device
v4l2: 0 frames successfully processed, 0 frames dropped.
Exiting... (End of file)
Any ideas????
Follows my dts
* Copyright (C) 2014 Freescale Semiconductor, Inc.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/dts-v1/;
#include <dt-bindings/gpio/gpio.h>
#include "imx6sx.dtsi"
#include "imx6sx-icore-pads.dtsi"
  model = "Engicam i.Core M6 SoloX";
  compatible = "fsl,imx6sx-icore", "fsl,imx6sx";
  backlight {
  compatible = "pwm-backlight";
  pwms = <&pwm5 0 50000>;
  brightness-levels = <0 4 8 16 32 64 128 255>;
  default-brightness-level = <6>;
  memory {
  reg = <0x80000000 0x40000000>;
  pxp_v4l2_out {
  compatible = "fsl,imx6sx-pxp-v4l2", "fsl,imx6sl-pxp-v4l2";
  status = "okay";
  regulators {
  compatible = "simple-bus";
  reg_3V3: 3V3{
  compatible = "regulator-fixed";
  regulator-name = "+3V3";
  regulator-min-microvolt = <3000000>;
  regulator-max-microvolt = <3000000>;
  regulator-always-on;
  reg_vref_3v3: regulator@0 {
  regulator-name = "vref-3v3";
  regulator-min-microvolt = <3300000>;
  regulator-max-microvolt = <3300000>;
  reg_psu_5v: psu_5v0 {
  regulator-name = "PSU-5V0";
  regulator-min-microvolt = <5000000>;
  regulator-max-microvolt = <5000000>;
  regulator-boot-on;
  reg_usb_otg1_vbus: usb_otg1_vbus {
  regulator-name = "usb_otg1_vbus";
  gpio = <&gpio1 9 0>;
  enable-active-high;
  reg_usb_otg2_vbus: usb_otg2_vbus {
  regulator-name = "usb_otg2_vbus";
  gpio = <&gpio1 12 0>;
  enable-active-high;
  sound {
  compatible = "fsl,imx6-icore-sgtl5000",
      "fsl,imx-audio-sgtl5000";
  model = "imx6q-icore-sgtl5000";
  cpu-dai = <&ssi1>;
  audio-codec = <&codec>;
  audio-routing =
  "LINE_IN", "Line In Jack",
  "Headphone Jack", "HP_OUT";
  mux-int-port = <1>;
  mux-ext-port = <6>;
&csi1 {
  status = "okay";
  port {
  csi1_ep: endpoint {
  remote-endpoint = <&adv7180_ep>;
&csi2 {
  status = "okay";
  port {
  csi2_ep: endpoint {
  remote-endpoint = <&vadc_ep>;
&dcic1 {
  dcic_id = <0>;
  dcic_mux = "dcic-lcdif1";
  status = "okay";
&dcic2 {
  dcic_id = <1>;
  dcic_mux = "dcic-lvds";
  status = "okay";
&adc1 {
  vref-supply = <&reg_vref_3v3>;
  status = "okay";
&adc2 {
  status = "okay";
&audmux {
  pinctrl-names = "default";
  pinctrl-0 = <&pinctrl_audmux_4>;
  status = "okay";
&fec1 {
  pinctrl-0 = <&pinctrl_enet1_2 &pinctrl_enet1_clkout_2>;
  pinctrl-assert-gpios = <&gpio6 19 GPIO_ACTIVE_HIGH>;
  phy-mode = "mii";
  fsl,num_tx_queues=<3>;
  fsl,num_rx_queues=<3>;
  status = "okay";
&fec2 {
  pinctrl-0 = <&pinctrl_enet2_2>;
  pinctrl-assert-gpios = <&gpio6 20 GPIO_ACTIVE_HIGH>;
  phy-mode = "mii";
  status = "okay";
&gpc {
  fsl,cpu_pupscr_sw2iso = <0xf>;
  fsl,cpu_pupscr_sw = <0xf>;
  fsl,cpu_pdnscr_iso2sw = <0x1>;
  fsl,cpu_pdnscr_iso = <0x1>;
  fsl,wdog-reset = <1>; /* watchdog select of reset source */
&i2c1 {
  clock-frequency = <100000>;
  pinctrl-0 = <&pinctrl_i2c1_1>;
  status = "okay";
  codec: sgtl5000@0a {
  compatible = "fsl,sgtl5000";
  reg = <0x0a>;
  clocks = <&clks IMX6SX_CLK_SSI1>;
  VDDA-supply = <&reg_3V3>;
  VDDIO-supply = <&reg_3V3>;
  polytouch: edt-ft5x06@38 {
  compatible = "edt,edt-ft5406";
  reg = <0x38>;
  pinctrl-0 = <&pinctrl_edt_ft5x06>;
  interrupt-parent = <&gpio1>;
  interrupts = <14 0>;
  reset-gpios = <&gpio1 0 16>;
  adv7180: adv7180@21 {
  compatible = "adv,adv7180";
  reg = <0x21>;
  pinctrl-0 = <&pinctrl_csi_2>;
  clocks = <&clks IMX6SX_CLK_CSI>;
  clock-names = "csi_mclk";
  DOVDD-supply = <&reg_3V3>; // 3.3v, enabled via 2.8 VGEN6
  AVDD-supply = <&reg_3V3>;  // 1.8v
  DVDD-supply = <&reg_3V3>;  // 1.8v
  PVDD-supply = <&reg_3V3>;  // 1.8v
  pwn-gpios = <&gpio3 19 0>;  // put on not used pin
  csi_id = <0>;
  mclk = <24000000>;
  mclk_source = <0>;
  cvbs = <1>;
  status = "okay";
  port {
  adv7180_ep: endpoint {
  remote-endpoint = <&csi1_ep>;
&i2c2 {
  pinctrl-0 = <&pinctrl_i2c2_2>;
  status = "okay";
  hdmi: edid@50 {
  compatible = "fsl,imx6-hdmi-i2c";
  reg = <0x50>;
&i2c3 {
  pinctrl-0 = <&pinctrl_i2c3_2>;
  status = "okay";
  max11801@48 {
  compatible = "maxim,max11801";
  reg = <0x48>;
  interrupt-parent = <&gpio6>;
  interrupts = <18 2>;
  work-mode = <0>;/*DCM mode*/
&flexcan1 {
  pinctrl-0 = <&pinctrl_flexcan1_2>;
  status = "okay";
&flexcan2 {
  pinctrl-0 = <&pinctrl_flexcan2_2>;
  status = "okay";
&iomuxc {
  pinctrl-0 = <&pinctrl_hog>;
  touchpanel{
  pinctrl_edt_ft5x06:  edt-ft5x06grp  {
  fsl,pins = <
  MX6SX_PAD_CSI_DATA00__GPIO1_IO_14 0x17059 /*interrupt*/
  MX6SX_PAD_CSI_DATA02__GPIO1_IO_16 0x17059 /*reset*/
  hog {
  pinctrl_hog: hoggrp {
  fsl,pins = <
  MX6SX_PAD_KEY_COL0__GPIO2_IO_10 0x17059 /* GPIO_SP0 */
  MX6SX_PAD_KEY_COL1__GPIO2_IO_11 0x17059 /* GPIO_SP1 */
  MX6SX_PAD_KEY_ROW0__GPIO2_IO_15 0x17059 /* GPIO_SP2 */
  MX6SX_PAD_KEY_ROW1__GPIO2_IO_16 0x17059 /* GPIO_SP3 */
  MX6SX_PAD_KEY_COL2__GPIO2_IO_12 0x17059 /* GPIO_SP4 */
  MX6SX_PAD_KEY_COL3__GPIO2_IO_13 0x17059 /* GPIO_SP5 */
  MX6SX_PAD_KEY_ROW2__GPIO2_IO_17 0x17059 /* GPIO_SP6 */
  MX6SX_PAD_KEY_ROW3__GPIO2_IO_18 0x17059 /* GPIO_SP7 */
  MX6SX_PAD_GPIO1_IO08__GPIO1_IO_8 0x17059 /* GPIO_SP8 */
  MX6SX_PAD_GPIO1_IO09__GPIO1_IO_9 0x17059 /* GPIO_SP9 */
  MX6SX_PAD_SD3_CLK__GPIO7_IO_0 0x17059 /* GPIO_SP10 */
  MX6SX_PAD_SD3_CMD__GPIO7_IO_1 0x17059 /* GPIO_SP11 */
  MX6SX_PAD_QSPI1B_SS1_B__GPIO4_IO_31 0x17059 /* GPIO_SP12 */
  MX6SX_PAD_QSPI1B_DQS__GPIO4_IO_28 0x17059 /* GPIO_SP13 */
  MX6SX_PAD_QSPI1B_DATA2__GPIO4_IO_26 0x17059 /* GPIO_SP14 */
  MX6SX_PAD_QSPI1B_DATA3__GPIO4_IO_27 0x17059 /* GPIO_SP15 */
  MX6SX_PAD_GPIO1_IO02__GPIO1_IO_2 0x17059 /* SD1_CD */
  MX6SX_PAD_SD4_DATA4__GPIO6_IO_18 0x17059 /* PEN_IRQ */
  MX6SX_PAD_SD4_DATA5__GPIO6_IO_19 0x17059 /* ETH_PHY1_RES */
  MX6SX_PAD_SD4_DATA6__GPIO6_IO_20 0x17059 /* ETH_PHY2_RES */
&pcie {
  power-on-gpio = <&gpio2 0 0>;
  reset-gpio = <&gpio2 1 0>;
  status = "okay";
&sai1 {
  pinctrl-0 = <&pinctrl_sai1_2>;
  status = "disabled";
&ssi1 {
  status = "okay";
&uart1 {
  pinctrl-0 = <&pinctrl_uart1_1>;
  status = "okay";
&uart2 {
  pinctrl-0 = <&pinctrl_uart2_1>;
  status = "okay";
&uart3 {
  pinctrl-0 = <&pinctrl_uart3_1>;
  fsl,uart-has-rtscts;
  status = "okay";
&gpmi {
  pinctrl-0 = <&pinctrl_gpmi_nand_1>;
  status = "okay";
&usbotg1 {
  vbus-supply = <&reg_usb_otg1_vbus>;
  pinctrl-0 = <&pinctrl_usbotg1_1>;
  imx6-usb-charger-detection;
  status = "okay";
&usbotg2 {
  vbus-supply = <&reg_usb_otg2_vbus>;
  dr_mode = "host";
  status = "okay";
&usdhc1 {
  pinctrl-0 = <&pinctrl_usdhc1_1>;
  cd-gpios = <&gpio1 2 0>;
  non-removable;
  no-1-8-v;
  vmmc-supply = <&reg_3V3>;
  status = "okay";
&usdhc2 {
  pinctrl-0 = <&pinctrl_usdhc2_1>;
  non-removable;
  no-1-8-v;
  keep-power-in-suspend;
  enable-sdio-wakeup;
  status = "okay";
&lcdif1 {
  pinctrl-0 = <&pinctrl_lcdif_dat_1
      &pinctrl_lcdif_ctrl_0>;
  lcd-supply = <&reg_3V3>;
  display = <&display0>;
  status = "okay";
  display0: display {
  bits-per-pixel = <16>;
  bus-width = <18>;
  display-timings {
  native-mode = <&timing0>;
  timing0: timing0 {
  clock-frequency = <33500000>;
  hactive = <800>;
  vactive = <480>;
  hback-porch = <89>;
  hfront-porch = <164>;
  vback-porch = <23>;
  vfront-porch = <10>;
  hsync-len = <10>;
  vsync-len = <10>;
  hsync-active = <0>;
  vsync-active = <0>;
  de-active = <1>;
  pixelclk-active = <0>;
&lcdif2 {
  display = <&display1>;
  disp-dev = "ldb";
  status = "okay";
  display1: display {
  bus-width = <18>;
&ldb {
  status = "okay";
  lvds-channel@0 {
  fsl,data-mapping = "spwg";
  fsl,data-width = <18>;
  crtc = "lcdif2";
  status = "okay";
  display-timings {
  native-mode = <&timing1>;
  timing1: hsd100pxn1 {
  clock-frequency = <65000000>;
  hactive = <1024>;
  vactive = <768>;
  hback-porch = <220>;
  hfront-porch = <40>;
  vback-porch = <21>;
  vfront-porch = <7>;
  hsync-len = <60>;
  vsync-len = <10>;
&pwm2 {
&pwm3 {
&pwm4 {
&pwm5 { /* LCD CONTRAST */
  pinctrl-0 = <&pinctrl_pwm5_0>;
  status = "okay";
&pxp {
  status = "okay";
&vadc {
  vadc_in = <0>;
  csi_id = <1>;
  status = "okay";
  port {
  vadc_ep: endpoint {
  remote-endpoint = <&csi2_ep>;
1,120 次查看
igorpadykov
for adv7180 it is necessary to use tv-in source plugin as described in attached Linux Guide
sect.7.3.8 Recording the TV-in source
Also I think one can try to test with imx-test, please check folder pxp_v4l2_test
http://repository.timesys.com/buildsources/i/imx-test/imx-test-3.14.28-1.0.0/
~igor
1,120 次查看
mirkoardinghi1
I'm using CONFIG_MXC_TVIN_ADV7180 in kernel config (I used CONFIG_VIDEO_AD7180 too but the result is the same). Doesn't work!
The result of pxp_v4l2_out_test.sh is:
unable to open /dev/video for output, continue searching device.
Found v4l2 output device /dev/video2.
V4L output 0 (0x8de00000): PxP Display Output
Video input format: 352x240 YUV 4:2:0 Planar
request count 6
win.w.l/t/w/h = 0/0/352/240
crop.c.l/t/w/h = 0/0/352/240
s0 data open failed: No such file or directory
request count 6
crop.c.l/t/w/h = 0/0/264/152
request count 6
request count 6
s1 data open failed: No such file or directory
1,120 次查看
igorpadykov
you are right: default driver supports sensor with sync signals, while adv7180 works
in ccir656 mode. One can look at attached example for i.MX21 with similar CSI
module and add support for ccir656 mode.
~igor
