Hi Qiang,
Are you using the BSP provided by freescale? In the i.MX_6_SABRE-SD_Linux_User's_Guide.pdf document, you can see details on 6.2 Download Images by U-Boot. Take the BSP L3.10.17_1.0.0 as an example, you can refer to the attachment file.
Hope this can help you. Any questions you can contact me easily.
Dan
Hi Qiang Wang,
What platform and which version of BSP are you using?
Dan
Hi Qiang,
Dan
Hi Qiang,
Have you solved your questions, if yes please help click the Correct Answer button, thank you.
Dan
Hi Qiang,
是要在内核启动以后,分区的命令才可以使用,我刚跟别的同事确认了一下,在u-boot中对EMMC分区的话是不可以的,没有命令可以使用。不过这是针对2012以及以前的版本,新版本2014版本的u-boot我们这边不是很清楚。
这里还是建议你使用NFS启动,或者是我上述给你的方法,对EMMC分区。希望对你有帮助。
Dan
