i.MX8 chromium hardware accelerated video decoding
i.MX8 VPU hardware decoder support below video codec:
H.265 HEVC Main Profile 4Kp60 Level 5.1
H.264 AVC Constrained Baseline, Main and High profile
H.264 MVC
WMV9 / VC-1 Simple, Main and Advanced Profile
MPEG 1 and 2 Main Profile at High Level
AVS Jizhun Profile (JP)
MJPEG4.2 ASP, H.263, Sorenson Spark
Divx 3.11, with Global Motion Compensation (GMC)
ON2/Google VP6/VP8
RealVideo 8/9/10
JPEG and MJPEG A/B Baseline
i.MX8 VPU Linux driver is implemented based on V4L2 standard.
Chromium beside software video decoding, it also support hardware video decoder(VideoDecodeAccelerator),  there are some kind of VideoDecodeAccelerator, one of them is V4L2VDA.
Please note V4L2VDA is using V4l2 api, so it is possible that change V4L2VDA to enable Chromium hardware video playback on i.MX8.
This doc share patch to add chromium video decode accelerate by using i.MX8QM/i.MX8QXP VPU.
It will support chromium H.264, H.265, VP8 hardware video decode.
H.264 and H.265 need use mp4 container.
VP8 use webm container.
HW: i.MX8QM/i.MX8QXP MEK board, 1080P HDMI display, mouse, keyboard
SW: i.MX8 5.10.72_2.2.2 yocto bsp release(which included chromium 91.0), and patch in this doc
Patch description:
imx8-5.10.72-vpudrv-update.diff, update i.MX8  5.10.72_2.2.2 kernel vpu driver to https://source.codeaurora.org/external/imx/linux-imx/commit/drivers/mxc/vpu_malone?h=lf-5.15.y&id=fa...
chromium-ozone-wayland_91.0.4472.114.bb.diff, change meta-browser/meta-chromium/recipes-browser/chromium/chromium-ozone-wayland_91.0.4472.114.bb for adding some compile flags, etc.
5.10.72-merge.patch, this patch change chromium source code to add video decode accelerate by using i.MX8 VPU.
Build steps:
1>Download i.MX8 5.10.72_2.2.2 yocto release from nxp.com
2>apply chromium-ozone-wayland_91.0.4472.114.bb.diff to change meta-browser/meta-chromium/recipes-browser/chromium/chromium-ozone-wayland_91.0.4472.114.bb
3>put 5.10.72-merge.patch to folder path_of_yocto-5.10.72-2.2.2/sources/meta-browser/meta-chromium/recipes-browser/chromium/files/
3>apply imx8-5.10.72-vpudrv-update.diff to i.MX8 5.10.72_2.2.2 kernel
4>under the yocto image build folder, add "CORE_IMAGE_EXTRA_INSTALL += "chromium-ozone-wayland" to file path_of_yocto-5.10.72-2.2.2/folder-of-bld/conf/local.conf
5>run bitbake to build rootfs image
Test steps:
After system boot up, put some video clip under /home/root/video
then run below cmd (do not run chromium without any parameter, as that will start chromium with some other setting, you can check /usr/lib/chromium/chromium-wrapper)
"/usr/lib/chromium/chromium-bin   --no-sandbox --ozone-platform=wayland
--enable-features=VaapiVideoDecoder  --enable-accelerated-video-decode
--enable-clear-hevc-for-testing
--ignore-gpu-blacklist --window-size=1920,1180  /home/root/video"
then use mouse to click video clip and will start playback.
Reference:
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
https://www.chromium.org/audio-video/#:~:text=codec%20and%20container%20support
https://github.com/igel-oss/meta-browser-hwdecode/blob/master/recipes-chromium/chromium/files/0001-A...
添付
コメント
How can I get this working for 5.10.52 kernel and a recent Chromium (e.g. 116+)?
And additional question: In case of most recent i.MX LF6.6.3_1.0.0 kernel, are there any patches in Chromium required? Or should Chromium 117 work then out-of-the-box?
%3CLINGO-SUB%20id%3D%22lingo-sub-1507243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%20Chromium%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1507243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%3CSPAN%3Ei.MX8%20VPU%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EH.265%20HEVC%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%204Kp60%20%E3%83%AC%E3%83%99%E3%83%AB%205.1%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EH.264%20AVC%20%E5%88%B6%E7%B4%84%E4%BB%98%E3%81%8D%E3%83%99%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%B3%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%8A%E3%82%88%E3%81%B3%E3%83%8F%E3%82%A4%E3%83%BB%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EH.264%20MVC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EWMV9%20%2F%20VC-1%20%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%80%81%E3%83%A1%E3%82%A4%E3%83%B3%E3%80%81%E3%82%A2%E3%83%89%E3%83%90%E3%83%B3%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMPEG%201%E3%81%8A%E3%82%88%E3%81%B32%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%BB%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%88%E3%83%8F%E3%82%A4%E3%83%AC%E3%83%99%E3%83%AB%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAVS%20Jizhun%20Profile%20(JP)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMJPEG4.2%20ASP%2C%20H.263%2C%20Sorenson%20Spark%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EDivx%203.11%E3%80%81%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E8%A3%9C%E6%AD%A3%20(GMC)%20%E4%BB%98%E3%81%8D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EON2%2FGoogle%20VP6%2FVP8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ERealVideo%208%2F9%2F10%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EJPEG%E3%81%8A%E3%82%88%E3%81%B3MJPEG%20A%2FB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3Ei.MX8%20VPU%20Linux%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%80%81V4L2%E6%A8%99%E6%BA%96%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChromium%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E4%BB%96%E3%81%AB%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%80%EF%BC%88VideoDecodeAccelerator%EF%BC%89%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3EVideoDecodeAccelerator%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E7%A8%AE%E9%A1%9E%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE1%E3%81%A4%E3%81%8CV4L2VDA%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%B3%A8%EF%BC%9AV4L2VDA%E3%81%AFV4l2%20API%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81i.MX8%E3%81%A7Chromium%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%93%E3%83%87%E3%82%AA%E5%86%8D%E7%94%9F%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81i.MX8QM%2Fi.MX8QXP%20VPU%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Chromium%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EChromium%20H.264%E3%80%81H.265%E3%80%81VP8%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EH.264%20%E3%81%8A%E3%82%88%E3%81%B3%20H.265%20%E3%81%AF%20mp4%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EVP8%20%E3%81%AF%20webm%20%E3%82%B3%E3%83%B3%E3%83%86%E3%83%8A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EHW%3A%20i.MX8QM%2Fi.MX8QXP%20MEK%E3%83%9C%E3%83%BC%E3%83%89%E3%80%811080P%20HDMI%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%80%81%E3%83%9E%E3%82%A6%E3%82%B9%E3%80%81%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESW%EF%BC%9Ai.MX8%205.10.72_2.2.2%20Yocto%20BSP%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%EF%BC%88Chromium%2091.0%E3%82%92%E5%90%AB%E3%82%80%EF%BC%89%E3%81%8A%E3%82%88%E3%81%B3%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E8%AA%AC%E6%98%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eimx8-5.10.72-vpudrv-update.diff%EF%BC%9Ai.MX8%26nbsp%3B%205.10.72_2.2.2%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%ABVPU%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%3C%2FSPAN%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2Fcommit%2Fdrivers%2Fmxc%2Fvpu_malone%3Fh%3Dlf-5.15.y%26amp%3Bid%3Dfa7c67e2c9ed4fb8392fa258f931d6996339a17a%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%2Flinux-imx%2Fcommit%2Fdrivers%2Fmxc%2Fvpu_malone%3Fh%3Dlf-5.15.y%26amp%3Bid%3Dfa7c67e2c9ed4fb8392fa258f931d6996339a17a%3C%2FA%3E%3C%2FSPAN%3E%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Echromium-ozone-wayland_91.0.4472.114.bb.diff%EF%BC%9A%E4%B8%80%E9%83%A8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%83%BB%E3%83%95%E3%83%A9%E3%82%B0%E3%81%AA%E3%81%A9%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABmeta-browser%2Fmeta-chromium%2Frecipes-browser%2Fchromium%2Fchromium-ozone-wayland_91.0.4472.114.bb%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E5.10.72-merge.patch%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E3%80%81Chromium%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81i.MX8%20VPU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%AB%98%E9%80%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E1%26gt%3Bnxp.com%E3%81%8B%E3%82%89i.MX8%205.10.72_2.2.2%E3%81%AEyocto%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E2%26gt%3Bchromium-ozone-wayland_91.0.4472.114.bb.diff%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81meta-browser%2Fmeta-chromium%2Frecipes-browser%2Fchromium%2Fchromium-ozone-wayland_91.0.4472.114.bb%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3%26gt%3B%EF%BC%9A5.10.72-merge.patch%E3%82%92%E3%80%8Cpath_of_yocto-5.10.72-2.2.2%2Fsources%2Fmeta-browser%2Fmeta-chromium%2Frecipes-browser%2Fchromium%2Ffiles%2F%E3%80%8D%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E3%26gt%3Bimx8-5.10.72-vpudrv-update.diff%E3%82%92i.MX8%205.10.72_2.2.2%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E4%26gt%3B%EF%BC%9AYocto%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%93%E3%83%AB%E3%83%89%E3%83%BB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AE%E4%B8%8B%E3%81%A7%E3%80%81%E3%80%8CCORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22chromium-ozone-wayland%E3%80%8D%E3%82%92file%20path_of_yocto-5.10.72-2.2.2%2Ffolder-of-bld%2Fconf%2Flocal.conf%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E5%26gt%3B%EF%BC%9Abitbake%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6rootfs%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%2Fhome%2Froot%2Fvideo%E3%81%AB%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%E3%81%ABChromium%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E4%BB%96%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BB%98%E3%81%91%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E3%80%81%2Fusr%2Flib%2Fchromium%2Fchromium-wrapper%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%22%2Fusr%2Flib%2Fchromium%2Fchromium-bin%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E--no-sandbox%20--ozone-platform%3Dwayland%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--enable-features%3DVaapiVideoDecoder%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E--enable-accelerated-video-decode%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--enable-clear-hevc-for-testing%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E--ignore-gpu-blacklist%20--window-size%3D1920%2C1180%20%2Fhome%2Froot%2Fvideo%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%9E%E3%82%A6%E3%82%B9%E3%81%A7%E3%83%93%E3%83%87%E3%82%AA%E3%83%BB%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%86%8D%E7%94%9F%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%3AIMX8-SERIES%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi-mx-applications-processors%2Fi-mx-8-processors%3AIMX8-SERIES%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fembedded-software%2Fi-mx-software%2Fembedded-linux-for-i-mx-applications-processors%3AIMXLINUX%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.chromium.org%2Faudio-video%2F%23%3A~%3Atext%3Dcodec%2520and%2520container%2520support%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.chromium.org%2Faudio-video%2F%23%3A~%3Atext%3Dcodec%2520and%2520container%2520support%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Figel-oss%2Fmeta-browser-hwdecode%2Fblob%2Fmaster%2Frecipes-chromium%2Fchromium%2Ffiles%2F0001-Add-support-for-V4L2VDA-on-Linux.patch%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Figel-oss%2Fmeta-browser-hwdecode%2Fblob%2Fmaster%2Frecipes-chromium%2Fchromium%2Ffiles%2F0001-Add-support-for-V4L2VDA-on-Linux.patch%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1507243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%7C%20i.MX%208QuadMax%E2%80%AF(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20Chromium%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E8%B3%AA%E5%95%8F%EF%BC%9A%E6%9C%80%E6%96%B0%E3%81%AEi.MX%20LF6.6.3_1.0.0%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Chromium%E3%81%AB%E3%83%91%E3%83%83%E3%83%81%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81Chromium117%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1861515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20Chromium%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%83%93%E3%83%87%E3%82%AA%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1861515%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E5.10.52%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E6%AF%94%E8%BC%83%E7%9A%84%E6%96%B0%E3%81%97%E3%81%84Chromium%EF%BC%88116%2B%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%97%E3%81%9F%E3%82%89%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
100%が役に立ったと言っています (2/2)
バージョン履歴
最終更新日:
‎08-18-2022 02:29 AM
更新者:
