i.MX35 PDK NAND Creating and Flashing UBIFS image
Search instead for
No ratings
Quick Steps
Four quick steps to build and flash a UBIFS image on i.MX35 NAND (K9LBG08U0D-PCB0), for information on how to you another memory, please see next section.
  1. Enable MTD_UBI and UBIFS_FS on kernel
  2. Create UBI image from rootfs (used for NFS) - ON PC
    1. mkfs.ubifs -v -r rootfs -m 2048 -e 258048 -c 966 -o ubifs.img
    2. ubinize -o ubi.img -m 2048 -p 256KiB -s 2048 ubinize.cfg
  3. Format NAND using UBI image - ON TARGET
    1. ubiformat -f ubi.img /dev/mtd8
  4. Load UBI file system
    1. load -r -b 0x100000 zImage
    2. fis create -f 0x300000 kernel
      1. fis load kernel
      2. exec -c "noinitrd console=ttymxc0 115200 ubi.mtd=8 root=ubi0:rootfs rw rootfstype=ubifs ip=none"
How To
First of all, install mtd-utils on both target and host:
Target:
./ltib -c
Package list
[*] mtd-utils
Host
sudo aptget install mtd-utils
MTD_UBI
-> Device Drivers
    -> Memory Technology Device (MTD) support (MTD [=y])
          -> UBI - Unsorted block images
                  <*> Enable UBI
                   (4096) UBI wear-leveling threshold (NEW)
                   (1) Percentage of reserved eraseblocks for bad eraseblocks handling (NEW)
                < > MTD devices emulation driver (gluebi) (NEW)
                   ** UBI debugging options **
                   [ ] UBI debugging (NEW)
UBIFS_FS
-> File systems
        ->Miscellaneous filesystems
            <*> UBIFS file system support
                [ ] Extended attributes support (NEW)
                [ ] Advanced compression options (NEW)
                [ ] Enable debugging (NEW)
2. Create UBI image
On TARGET Collect some information needed in order to create the UBI image according to your NAND device
root@freescale \~$ cat /proc/mtd
dev:   size   erasesize name
mtd0: 00080000 00020000 "Bootloader"
mtd1: 00400000 00020000 "nor.Kernel"
mtd2: 01e00000 00020000 "nor.userfs"
mtd3: 01c00000 00020000 "nor.rootfs"
mtd4: 00003000 00020000 "FIS directory"
mtd5: 02001000 00020000 "Redboot config"
mtd6: 00300000 00040000 "nand.bootloader"
mtd7: 00500000 00040000 "nand.kernel"
mtd8: 10000000 00040000 "nand.rootfs"
mtd9: 00800000 00040000 "nand.configure"
mtd10: 6f000000 00040000 "nand.userfs"
I will use mtd8, because I want the NAND rootfs MTD partition.
More on [1]
root@freescale ~$ ubiattach /dev/ubi_ctrl -m 8
UBI: attaching mtd8 to ubi0
UBI: physical eraseblock size:   262144 bytes (256 KiB)
UBI: logical eraseblock size:    258048 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: empty MTD device detected
UBI: create volume table (copy #1)
UBI: create volume table (copy #2)
UBI: attached mtd8 to ubi0
UBI: MTD device name:            "nand.rootfs"
UBI: MTD device size:            256 MiB
UBI: number of good PEBs:        979
UBI: number of bad PEBs:         45
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     0
UBI: available PEBs:             966
UBI: total number of reserved PEBs: 13
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 0/0
UBI: image sequence number: 0
UBI: background thread "ubi_bgt0d" started, PID 2098
UBI device number
You will need:
  • -p = physical eraseblock size = 256KiB
  • -e = logical eraseblock size = 258048
  • -m = smallest flash I/O unit = 2048
  • -s = VID header offset = 2048
  • -c = available PEB = 966
Values only for iMX35 PDK NAND - K9LBG08U0D-PCB0
3. ON HOST - Now, create the images (two steps)
You need to create ubinize.cfg file!
ubinize.cfg
[ubifs]
mode=ubi
image=ubifs.img
vol_id=0
vol_size=237MiB
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
$ mkfs.ubifs -v -r rootfs -m 2048 -e 258048 -c 966 -o ubifs.img
mkfs.ubifs
     root:                rootfs/
     min_io_size:    2048
     leb_size:         258048
     max_leb_cnt:   966
     output:            ubifs.img
     jrn_size:          8388608
     reserved:         0
     compr:            lzo
     keyhash:         r5
     fanout:            8
     orph_lebs:       1
     super lebs:      1
     master lebs:    2
     log_lebs:         4
     lpt_lebs:          2
     orph_lebs:       1
     main_lebs:       132
     gc lebs:           1
     index lebs:       2
     leb_cnt:           142
     UUID:              CC2057F9-B20F-46D1-A399-1FCA95DCAFF7
Success\!
$ ubinize -o ubi.img -m 2048 -p 256KiB -s 2048 ubinize.cfg
$ ls -lh u*
-rw-r--r-- 1 daiane daiane 35M 2010-11-26 15:21 ubifs.img
-rw-r--r-- 1 daiane daiane 36M 2010-11-26 15:22 ubi.img
-rw-r--r-- 1 daiane daiane 113 2010-11-26 15:22 ubinize.cfg
$ sudo cp ubi.img rootfs/home/
4. Format NAND using UBI image - ON TARGET
Turn on target (or reset it) and format MTD partition
$ cd /home
$ ubiformat -f ubi.img /dev/mtd8
5. Load UBI file system
Reset and change redboot script:
.. fis load kernel
.. exec -c "noinitrd console=ttymxc0 115200 ubi.mtd=8 root=ubi0:rootfs rw rootfstype=ubifs ip=none"
Tags (2)
Version history
Last update:
‎09-10-2020 03:05 AM
Updated by:
