Interfacing Depth Sensors on NXP i.MX6 boards
About this document
This document describe the setup detail for Interfacing, Installing, programming (basis) and testing depth cameras with MX6QDL based boards using Ubuntu as rootfs on i.MX6 processors boards.
Supported NXP HW boards:
  • i.MX 6QuadPlus SABRE-SD Board and Platform
  • i.MX 6Quad SABRE-SD Board and Platform
  • i.MX 6DualLite SABRE-SD Board
  • i.MX 6Quad SABRE-AI Board
  • i.MX 6DualLite SABRE-AI Board
  • Depth sensors tested: Microsoft Kinect, ASUS Xtion. Prime Sense Carmine
Software:   Gcc, Ubuntu 14.04v,  Openni, Python, ROS.
1. Depth Sensor
Depth sensors are 3D vision sensors, mainly used in 3D vision application and motion gaming and robotics. For this paper we are going to use Kinect sensor and Asus Xtion connection to i.MX6 Processor boards and will get 3D images that are converted to finer points called point cloud.
a) Microsoft Kinect
Kinect mainly has an IR camera, IR projector and RGB camera, the IR and projector generates the 3D point cloud of the surroundings. It also has a mic array and motorized tilt for moving up and down.
Kinect reveal that both the video and depth sensor cameras have a 640 x 480-pixel resolution and run at 30 FPS (frames per second). The RGB camera capture 2D color images, whereas the depth camera captures monochrome depth images. Kinect has a depth sensing range from 0.8mts to 3.5 mts
b) Asus Xtion:
Another alternative to kinect is Asus Xtion Pro.  Is a 3D sensor designed for motion sensing applications, this sensor is only for 3D sensing and it doesn’t have sound sensing. It has an infrared projector and a monochrome CMOS sensor to capture the infrared data. Xtion can be powered from USB itself and can calculate a sense depth from 0.8mts to 3.5 mts from the sensor.
c) Prime Sense Carmine:
The Prime Sense team (apple bought this company in November 2013) developed the Microsoft Kinect 3D vision, later develop their own 3D vision sensor Carmine. It also works with IR projector, RGB CMOS sensor and a depth CMOS sensor. All sensor are interfaced in System On Chip and is powered trough USB. Carmine capture 640x480 at 30 FPS and can sense from 0.35 mts to 3 mts. Developers can program the device using OpenNI and its wrapper libraries.
All these sensors (Kinect, Carmine and Xtion) support the same software, so there is no special need for programming or general usage. Can be interface to i.MX processor using USB 2.0 interface and programmed using OPENNI and OPENCV.
2. Installation on Ubuntu
For installation steps of Ubuntu trusty on iMX6 boards in your board, please follow up:
https://community.freescale.com/docs/DOC-330147
Install the dependencies:
$ sudo apt-get install -y g++ git python libusb-1.0-0-dev libudev-dev freeglut3-dev doxygen graphviz openjdk-6-jdk libxmu-dev libxi-dev
Create a devel folder
$  sudo mkdir –p devel
$ cd devel
Get OpenNI and the drivers $ git clone https://github.com/OpenNI/OpenNI.git -b unstable $ git clone git://github.com/ph4m/SensorKinect.git
$ git clone https://github.com/PrimeSense/Sensor.git -b unstable
Set the compile flags to build for the i.MX
$ nano OpenNI/Platform/Linux/CreateRedist/Redist_OpenNi.py
To: MAKE_ARGS += ' –j2'
Must also change the Arm compiler settings for this distribution
$ nano OpenNI/Platform/Linux/Build/Common/Platform.Arm
From: CFLAGS += -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp #-mcpu=cortex-a8
To: CFLAGS += -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard
Then run
$ cd OpenNI/Platform/Linux/CreateRedist/ $ ./RedistMaker.Arm $ cd ../Redist/OpenNI-Bin-Dev-Linux-Arm-v1.5.x.x $ sudo ./install.sh
Also edit the Sensor and SensorKinect makefile CFLAGS parameters
$cd ~/devel/
$ nano Sensor/Platform/Linux/Build/Common/Platform.Arm $ nano  SensorKinect/Platform/Linux/Build/Common/Platform.Arm
For both files From: CFLAGS += -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp #-mcpu=cortex-a8
And the Sensor and SensorKinect redistribution scripts
$ nano Sensor/Platform/Linux/CreateRedist/RedistMaker $ nano SensorKinect/Platform/Linux/CreateRedist/RedistMaker
for both, change: make -j$(calc_jobs_number) -C ../Build
to: make –j2 -C ../Build
The create the redistributables Sensor (xtion and primesense) and Kinect (sensor Kinect)
$ cd Sensor/Platform/Linux/CreateRedist/ $ ./RedistMaker Arm
$ cd ~/devel/
$ cd SensorKinect/Platform/Linux/CreateRedist/ $ ./RedistMaker Arm
$ cd ~/devel/
Then install PrimeSense and Kinect
$ cd Sensor/Platform/Linux/Redist/Sensor-Bin-Linux-Arm-v5.1.x.x $ sudo ./install.sh
$ cd ~/devel/SensorKinect/Platform/Linux/Redist/Sensor-Bin-Linux-Arm-v5.1.2.x $ sudo ./install.sh
3. Testing Installation:
Connect the sensor power supply, Connect the Kinect to the NXP board USB port. (check with lsusb). For my board:
Imx6q@imx6q:~/devel$ lsusb
Bus 001 Device 022: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
Bus 001 Device 021: ID 045e:02ad Microsoft Corp. Xbox NUI Audio
Bus 001 Device 019: ID 045e:02c2 Microsoft Corp. Kinect for Windows NUI Motor
Now edit theglobal Kinect settings in Ubuntu
$ sudo nano /usr/etc/primesense/GlobalDefaultsKinect.ini
and uncomment this line UsbInterface=1
and changed it to 1 instead of 2
UsbInterface=2
$ sudo modprobe -r gspca_kinect
And then blacklisting to avoid it to be auto-loaded on boot:
$ sudo sh -c 'echo "blacklist gspca_kinect" > /etc/modprobe.d/blacklist-kinect.conf'
Then:
$ cd ~/devel/OpenNI/Platform/Linux/Bin/Arm-Release
$ sudo ./Sample-NiSimpleRead
You should get something like:
Reading config from: '../../../../Data/SamplesConfig.xml'
Frame 40 Middle point is: 5050. FPS: 30.771788
Frame 41 Middle point is: 5050. FPS: 30.866173
Frame 42 Middle point is: 5050. FPS: 30.850958
Frame 43 Middle point is: 5050. FPS: 30.779032
Frame 44 Middle point is: 5050. FPS: 30.767746
Frame 45 Middle point is: 5050. FPS: 30.800463
Frame 46 Middle point is: 5050. FPS: 30.653118
Frame 47 Middle point is: 5050. FPS: 30.741659
Frame 98 Middle point is: 5050. FPS: 30.339321
LibFreenect:
$ cd ~/devel/
$ git clone https://github.com/OpenKinect/libfreenect.git $ cd libfreenect $ mkdir build $ cd build $ cmake .. –L –DBUILD_AUDIO=ON $ make $ sudo make install
Connect the kinect sensor power supply, connect the Kinect to the NXP board USB port and test any sample such as:
$ sudo freenect-glview
Note: If glview gives a shared library error:
You need to refresh your ldconfig cache. The easiest way to do this is to create a file usr-local-libs.conf (or whatever name you wish) with the following lines:
/usr/local/lib
Switch to root account and move it to /etc/ld.so.conf.d/usr-local-libs.conf. Then update the ldconfig cache:
$ su root
$ mv ~/usr-local-libs.conf /etc/ld.so.conf.d/usr-local-libs.conf
$ /sbin/ldconfig –v
$ exit
References:
1)      https://openkinect.org/
2)      https://www.asus.com/us/3D-Sensor/Xtion_PRO_LIVE/
3)      Learning Robotics using phyton by Lentin Joseph. http://www.amazon.com/Learning-Robotics-Python-Lentin-Joseph/dp/1783287535/ref=sr_1_1
4)      Computer Vision on i.MX Processors
%3CLINGO-SUB%20id%3D%22lingo-sub-1128984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENXP%20i.MX6%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%8E%A5%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2013.0pt%3B%22%3E%3CSTRONG%3E%E5%85%B3%E4%BA%8E%E6%9C%AC%E6%96%87%E6%A1%A3%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%BD%BF%E7%94%A8%20Ubuntu%20%E4%BD%9C%E4%B8%BA%20i.MX6%20%E5%A4%84%E7%90%86%E5%99%A8%E6%9D%BF%E4%B8%8A%E7%9A%84%20rootfs%20%E6%9D%A5%E8%BF%9E%E6%8E%A5%E3%80%81%E5%AE%89%E8%A3%85%E3%80%81%E7%BC%96%E7%A8%8B%EF%BC%88%E5%9F%BA%E7%A1%80%EF%BC%89%E5%92%8C%E6%B5%8B%E8%AF%95%E5%9F%BA%E4%BA%8E%20MX6QDL%20%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E7%9A%84%E6%B7%B1%E5%BA%A6%E6%91%84%E5%83%8F%E5%A4%B4%E7%9A%84%E8%AE%BE%E7%BD%AE%E7%BB%86%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3E%E6%94%AF%E6%8C%81%E7%9A%84%20NXP%20%E7%A1%AC%E4%BB%B6%E6%9D%BF%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3Ei.MX%206QuadPlus%20SABRE-SD%20%E5%BC%80%E5%8F%91%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3Ei.MX%206Quad%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%E5%92%8C%E5%B9%B3%E5%8F%B0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3Ei.MX%206DualLite%20SABRE-SD%20%E4%B8%BB%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3Ei.MX%206Quad%20SABRE-AI%E7%94%B5%E8%B7%AF%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3Ei.MX%206DualLite%20SABRE-AI%20%E6%9D%BF%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Cambria'%2C'serif'%3B%22%3E%E6%B5%8B%E8%AF%95%E7%9A%84%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%9AMicrosoft%20Kinect%E3%80%81ASUS%20Xtion%E3%80%82Prime%20Sense%20%E8%83%AD%E8%84%82%E7%BA%A2%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20.25in%3B%22%3E%3CSTRONG%3E%E8%BD%AF%E4%BB%B6%EF%BC%9A%3C%2FSTRONG%3E%20Gcc%E3%80%81Ubuntu%2014.04v%E3%80%81Openni%E3%80%81Python%E3%80%81ROS%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20.25in%3B%22%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382579246%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-382579246%22%20id%3D%22toc-hId-1303209497%22%3E1.%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FH1%3E%3CP%3E%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%98%AF3D%E8%A7%86%E8%A7%89%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E4%B8%BB%E8%A6%81%E7%94%A8%E4%BA%8E3D%E8%A7%86%E8%A7%89%E5%BA%94%E7%94%A8%E5%92%8C%E8%BF%90%E5%8A%A8%E6%B8%B8%E6%88%8F%E5%92%8C%E6%9C%BA%E5%99%A8%E4%BA%BA%E6%8A%80%E6%9C%AF%E3%80%82%E5%9C%A8%E6%9C%AC%E6%96%87%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%BD%BF%E7%94%A8%20Kinect%20%E4%BC%A0%E6%84%9F%E5%99%A8%E5%92%8C%20Asus%20Xtion%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20i.MX6%20%E5%A4%84%E7%90%86%E5%99%A8%E6%9D%BF%EF%BC%8C%E5%B9%B6%E5%B0%86%E8%8E%B7%E5%BE%97%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9B%B4%E7%B2%BE%E7%BB%86%E7%82%B9%EF%BC%88%E7%A7%B0%E4%B8%BA%E7%82%B9%E4%BA%91%EF%BC%89%E7%9A%84%203D%20%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ea)%20%E5%BE%AE%E8%BD%AF%20Kinect%3C%2FP%3E%3CP%3EKinect%E4%B8%BB%E8%A6%81%E6%9C%89%E7%BA%A2%E5%A4%96%E6%91%84%E5%83%8F%E5%A4%B4%E3%80%81%E7%BA%A2%E5%A4%96%E6%8A%95%E5%BD%B1%E4%BB%AA%E5%92%8CRGB%E6%91%84%E5%83%8F%E5%A4%B4%EF%BC%8C%E7%BA%A2%E5%A4%96%E6%91%84%E5%83%8F%E5%A4%B4%E5%92%8C%E6%8A%95%E5%BD%B1%E4%BB%AA%E7%94%9F%E6%88%90%E5%91%A8%E5%9B%B4%E7%8E%AF%E5%A2%83%E7%9A%843D%E7%82%B9%E4%BA%91%E3%80%82%E5%AE%83%E8%BF%98%E5%85%B7%E6%9C%89%E9%BA%A6%E5%85%8B%E9%A3%8E%E9%98%B5%E5%88%97%E5%92%8C%E5%8F%AF%E4%B8%8A%E4%B8%8B%E7%A7%BB%E5%8A%A8%E7%9A%84%E7%94%B5%E5%8A%A8%E5%80%BE%E6%96%9C%E8%A3%85%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3EKinect%20%E6%98%BE%E7%A4%BA%EF%BC%8C%E8%A7%86%E9%A2%91%E5%92%8C%E6%B7%B1%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%E6%91%84%E5%83%8F%E5%A4%B4%E5%9D%87%E5%85%B7%E6%9C%89%20640%20x%20480%20%E5%83%8F%E7%B4%A0%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%E4%B8%BA%2030%20FPS%EF%BC%88%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%89%E3%80%82RGB%20%E7%9B%B8%E6%9C%BA%E6%8D%95%E8%8E%B7%202D%20%E5%BD%A9%E8%89%B2%E5%9B%BE%E5%83%8F%EF%BC%8C%E8%80%8C%E6%B7%B1%E5%BA%A6%E7%9B%B8%E6%9C%BA%E6%8D%95%E8%8E%B7%E5%8D%95%E8%89%B2%E6%B7%B1%E5%BA%A6%E5%9B%BE%E5%83%8F%E3%80%82Kinect%20%E7%9A%84%E6%B7%B1%E5%BA%A6%E6%84%9F%E5%BA%94%E8%8C%83%E5%9B%B4%E4%B8%BA%200.8%20%E7%B1%B3%E8%87%B3%203.5%20%E7%B1%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20align%3D%22center%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20339px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27586i780621ECD0C00B58%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eb)%20%E5%8D%8E%E7%A1%95%20Xtion%EF%BC%9A%3C%2FP%3E%3CP%3EKinect%20%E7%9A%84%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%9B%BF%E4%BB%A3%E5%93%81%E6%98%AF%20Asus%20Xtion%20Pro%E3%80%82%E6%98%AF%E4%B8%80%E6%AC%BE%E4%B8%93%E4%B8%BA%E8%BF%90%E5%8A%A8%E6%84%9F%E5%BA%94%E5%BA%94%E7%94%A8%E8%80%8C%E8%AE%BE%E8%AE%A1%E7%9A%84%203D%20%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E8%AF%A5%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BB%85%E7%94%A8%E4%BA%8E%203D%20%E6%84%9F%E5%BA%94%EF%BC%8C%E4%B8%8D%E5%85%B7%E5%A4%87%E5%A3%B0%E9%9F%B3%E6%84%9F%E5%BA%94%E5%8A%9F%E8%83%BD%E3%80%82%E5%AE%83%E6%9C%89%E4%B8%80%E4%B8%AA%E7%BA%A2%E5%A4%96%E6%8A%95%E5%BD%B1%E4%BB%AA%E5%92%8C%E4%B8%80%E4%B8%AA%E5%8D%95%E8%89%B2CMOS%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9D%A5%E6%8D%95%E6%8D%89%E7%BA%A2%E5%A4%96%E6%95%B0%E6%8D%AE%E3%80%82Xtion%20%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20USB%20%E6%9C%AC%E8%BA%AB%E4%BE%9B%E7%94%B5%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E8%AE%A1%E7%AE%97%E8%B7%9D%E7%A6%BB%E4%BC%A0%E6%84%9F%E5%99%A8%200.8%20%E7%B1%B3%E5%88%B0%203.5%20%E7%B1%B3%E7%9A%84%E6%84%9F%E5%BA%94%E6%B7%B1%E5%BA%A6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20352px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27627i90D9A238EB1E56F2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ec)%20Prime%20Sense%20%E8%83%AD%E8%84%82%E7%BA%A2%EF%BC%9A%3C%2FP%3E%3CP%3EPrime%20Sense%20%E5%9B%A2%E9%98%9F%EF%BC%88%E8%8B%B9%E6%9E%9C%E4%BA%8E%202013%20%E5%B9%B4%2011%20%E6%9C%88%E6%94%B6%E8%B4%AD%E4%BA%86%E8%BF%99%E5%AE%B6%E5%85%AC%E5%8F%B8%EF%BC%89%E5%BC%80%E5%8F%91%E4%BA%86%E5%BE%AE%E8%BD%AF%20Kinect%203D%20%E8%A7%86%E8%A7%89%EF%BC%8C%E5%90%8E%E6%9D%A5%E5%8F%88%E5%BC%80%E5%8F%91%E4%BA%86%E8%87%AA%E5%B7%B1%E7%9A%84%203D%20%E8%A7%86%E8%A7%89%E4%BC%A0%E6%84%9F%E5%99%A8%20Carmine%E3%80%82%E5%AE%83%E8%BF%98%E5%8F%AF%E4%B8%8E%E7%BA%A2%E5%A4%96%E6%8A%95%E5%BD%B1%E4%BB%AA%E3%80%81RGB%20CMOS%20%E4%BC%A0%E6%84%9F%E5%99%A8%E5%92%8C%E6%B7%B1%E5%BA%A6%20CMOS%20%E4%BC%A0%E6%84%9F%E5%99%A8%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%E6%89%80%E6%9C%89%E4%BC%A0%E6%84%9F%E5%99%A8%E5%9D%87%E4%B8%8E%E7%89%87%E4%B8%8A%E7%B3%BB%E7%BB%9F%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%80%9A%E8%BF%87%20USB%20%E4%BE%9B%E7%94%B5%E3%80%82Carmine%20%E4%BB%A5%2030%20FPS%20%E7%9A%84%E9%80%9F%E5%BA%A6%E6%8D%95%E6%8D%89%20640x480%20%E7%9A%84%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E6%84%9F%E7%9F%A5%200.35%20%E7%B1%B3%E5%88%B0%203%20%E7%B1%B3%E7%9A%84%E8%8C%83%E5%9B%B4%E3%80%82%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20OpenNI%20%E5%8F%8A%E5%85%B6%E5%8C%85%E8%A3%85%E5%BA%93%E5%AF%B9%E8%AE%BE%E5%A4%87%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20409px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27749i5047E4D58E6592CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E6%9C%89%E8%BF%99%E4%BA%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88Kinect%E3%80%81Carmine%20%E5%92%8C%20Xtion%EF%BC%89%E9%83%BD%E6%94%AF%E6%8C%81%E7%9B%B8%E5%90%8C%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E9%9C%80%E8%A6%81%E7%89%B9%E6%AE%8A%E7%BC%96%E7%A8%8B%E6%88%96%E4%B8%80%E8%88%AC%E4%BD%BF%E7%94%A8%E3%80%82%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20USB%202.0%20%E6%8E%A5%E5%8F%A3%E8%BF%9E%E6%8E%A5%E5%88%B0%20i.MX%20%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20OPENNI%20%E5%92%8C%20OPENCV%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424875217%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--1424875217%22%20id%3D%22toc-hId--504244966%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1062637616%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1062637616%22%20id%3D%22toc-hId-1983267867%22%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId--744816847%22%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--744816847%22%20id%3D%22toc-hId-175813404%22%3E2.%20%E5%9C%A8%20Ubuntu%20%E4%B8%8A%E5%AE%89%E8%A3%85%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E6%9C%89%E5%85%B3%E5%9C%A8%E6%82%A8%E7%9A%84%E4%B8%BB%E6%9D%BF%E4%B8%8A%E5%9C%A8%20iMX6%20%E6%9D%BF%E4%B8%8A%E5%AE%89%E8%A3%85%20Ubuntu%20Trusty%20%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-330147%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-330147%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%AE%89%E8%A3%85%E4%BE%9D%E8%B5%96%E9%A1%B9%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14595447440001183%22%20data-renderedposition%3D%221580.763916015625_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14595447440001183%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%22%3E%24%20sudo%20apt-get%20install%20-y%20g%2B%2B%20git%20python%20libusb-1.0-0-devlibudev-dev%20freeglut3-dev%20doxygen%20graphviz%20openjdk-6-jdk%20libxmu-dev%20libxi-dev%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%88%9B%E5%BB%BA%20devel%20%E6%96%87%E4%BB%B6%E5%A4%B9%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_145954478804858%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221621.8751220703125_50.000003814697266_1158_100%22%20jivemacro_uid%3D%22_145954478804858%22%3E%3CP%20class%3D%22Code%22%3E%24%20sudo%20mkdir%20%E2%80%93p%20devel%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20devel%20%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%20%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%20background%3A%20white%3B%22%3E%E8%8E%B7%E5%8F%96%20OpenNI%20%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%24%20git%20clone%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOpenNI%2FOpenNI.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20class%3D%22CodeCar%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FOpenNI%2FOpenNI.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FOpenNI%2FOpenNI.git%3C%2FA%3E%20-b%20%E4%B8%8D%E7%A8%B3%E5%AE%9A%0A%24%20git%20clone%20git%3A%2F%2Fgithub.com%2Fph4m%2FSensorKinect.git%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22background%3A%20white%3B%22%3E%24%20git%20clone%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FPrimeSense%2FSensor.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23888888%3B%20background%3A%20white%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FPrimeSense%2FSensor.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FPrimeSense%2FSensor.git%3C%2FA%3E%20%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22background%3A%20white%3B%22%3E-b%20%E4%B8%8D%E7%A8%B3%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%E8%AE%BE%E7%BD%AE%E7%BC%96%E8%AF%91%E6%A0%87%E5%BF%97%E4%BB%A5%E6%9E%84%E5%BB%BA%20i.MX%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14595448302604150%20jive_text_macro%22%20data-renderedposition%3D%221772.9862060546875_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14595448302604150%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%24%20nano%20OpenNI%2FPlatform%2FLinux%2FCreateRedist%2FRedist_OpenNi.py%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E4%BB%8E%EF%BC%9A%0A%20MAKE_ARGS%20%2B%3D%20'%20-j'%20%2B%20calc_jobs_number()%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E5%88%B0%EF%BC%9A%0A%20%3CEM%3EMAKE_ARGS%20%2B%3D%20'%20%E2%80%93j2'%3C%2FEM%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%E8%BF%98%E5%BF%85%E9%A1%BB%E6%9B%B4%E6%94%B9%E6%AD%A4%E5%8F%91%E8%A1%8C%E7%89%88%E7%9A%84%20Arm%20%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14595448651386884%22%20data-renderedposition%3D%221901.8751220703125_50.000003814697266_1158_78%22%20jivemacro_uid%3D%22_14595448651386884%22%3E%3CP%20class%3D%22Code%22%3E%24%20nano%20OpenNI%2FPlatform%2FLinux%2FBuild%2FCommon%2FPlatform.Arm%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.5pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%22%3E%E4%BB%8E%EF%BC%9A%0A%20CFLAGS%20%2B%3D%20-march%3Darmv7-a%20-mtune%3Dcortex-a8%20-mfpu%3Dneon%20-mfloat-abi%3Dsoftfp%20%23-mcpu%3Dcortex-a8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.5pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%22%3E%E5%88%B0%EF%BC%9A%0A%20CFLAGS%20%2B%3D%20-mtune%3Darm1176jzf-s%20-mfpu%3Dvfp%20-mfloat-abi%3Dhard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%22%3E%E7%84%B6%E5%90%8E%E8%BF%90%E8%A1%8C%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14595448875543108%20jive_text_macro%22%20data-renderedposition%3D%222030.7640380859375_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14595448875543108%22%3E%3CP%3E%24%20cd%20OpenNI%2FPlatform%2FLinux%2FCreateRedist%2F%0A%20%24.%2FRedistMaker.Arm%0A%20%24%20cd%20..%2FRedist%2FOpenNI-Bin-Dev-Linux-Arm-v1.5.xx%0A%20%24%20sudo%20.%2Finstall.sh%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%22%3E%E8%BF%98%E8%A6%81%E7%BC%96%E8%BE%91%20Sensor%20%E5%92%8C%20SensorKinect%20makefile%20CFLAGS%20%E5%8F%82%E6%95%B0%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14595449235304562%22%20data-renderedposition%3D%222144.097412109375_50.000003814697266_1158_109%22%20jivemacro_uid%3D%22_14595449235304562%22%3E%3CP%20class%3D%22Code%22%3E%24cd%20~%2Fdevel%2F%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20nano%20%E4%BC%A0%E6%84%9F%E5%99%A8%2F%E5%B9%B3%E5%8F%B0%2FLinux%2FBuild%2FCommon%2FPlatform.Arm%0A%20%24%20nano%20SensorKinect%2FPlatform%2FLinux%2FBuild%2FCommon%2FPlatform.Arm%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.5pt%3B%22%3E%E5%AF%B9%E4%BA%8E%E4%B8%A4%E4%B8%AA%E6%96%87%E4%BB%B6%E6%9D%A5%E8%87%AA%EF%BC%9A%0A%20CFLAGS%20%2B%3D%20-march%3Darmv7-a%20-mtune%3Dcortex-a8%20-mfpu%3Dneon%20-mfloat-abi%3Dsoftfp%20%23-mcpu%3Dcortex-a8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20style%3D%22font-size%3A%208.5pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%22%3E%E5%88%B0%EF%BC%9A%0A%20CFLAGS%20%2B%3D%20-mtune%3Darm1176jzf-s%20-mfpu%3Dvfp%20-mfloat-abi%3Dhard%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%22%3E%E4%BB%A5%E5%8F%8A%20Sensor%20%E5%92%8C%20SensorKinect%20%E9%87%8D%E6%96%B0%E5%88%86%E5%8F%91%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14595449671352693%20jive_text_macro%22%20data-renderedposition%3D%222304.097412109375_50.000003814697266_1158_93%22%20jivemacro_uid%3D%22_14595449671352693%22%3E%3CP%20class%3D%22Code%22%3E%24%E7%BA%B3%E7%B1%B3%E4%BC%A0%E6%84%9F%E5%99%A8%2F%E5%B9%B3%E5%8F%B0%2FLinux%2FCreateRedist%2FRedistMaker%0A%20%24%20nano%20SensorKinect%2FPlatform%2FLinux%2FCreateRedist%2FRedistMaker%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%20%E5%AF%B9%E4%BA%8E%E4%B8%A4%E8%80%85%EF%BC%8C%E6%94%B9%E5%8F%98%EF%BC%9A%0A%20make%20-j%24(calc_jobs_number)%20-C%20..%2FBuild%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E5%88%B0%EF%BC%9A%0A%E5%88%B6%E4%BD%9C-j2%20-C%20..%2F%E6%9E%84%E5%BB%BA%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%205.95pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%22%3E%20%E5%88%9B%E5%BB%BA%E5%8F%AF%E5%86%8D%E5%8F%91%E8%A1%8C%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88xtion%20%E5%92%8C%20primesense%EF%BC%89%E5%92%8C%20Kinect%EF%BC%88%E4%BC%A0%E6%84%9F%E5%99%A8%20Kinect%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14595450149833786%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%222456.45849609375_50.000003814697266_1158_93%22%20jivemacro_uid%3D%22_14595450149833786%22%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20%E4%BC%A0%E6%84%9F%E5%99%A8%2F%E5%B9%B3%E5%8F%B0%2FLinux%2FCreateRedist%2F%0A%20%24.%2FRedistMaker%E6%89%8B%E8%87%82%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20~%2Fdevel%2F%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20SensorKinect%2FPlatform%2FLinux%2FCreateRedist%2F%0A%20%24.%2FRedistMaker%E6%89%8B%E8%87%82%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20~%2Fdevel%2F%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%205.95pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Trebuchet%20MS'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%22%3E%E7%84%B6%E5%90%8E%E5%AE%89%E8%A3%85%20PrimeSense%20%E5%92%8C%20Kinect%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14595450584039027%20jive_text_macro%22%20data-renderedposition%3D%222608.819580078125_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14595450584039027%22%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20%E4%BC%A0%E6%84%9F%E5%99%A8%2F%E5%B9%B3%E5%8F%B0%2FLinux%2FRedist%2FSensor-Bin-Linux-Arm-v5.1.xx%0A%20%24%20sudo%20.%2Finstall.sh%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20~%2Fdevel%2FSensorKinect%2FPlatform%2FLinux%2FRedist%2FSensor-Bin-Linux-Arm-v5.1.2.x%0A%20%24%20sudo%20.%2Finstall.sh%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23666666%3B%22%3E3.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23666666%3B%22%3E%E6%B5%8B%E8%AF%95%E5%AE%89%E8%A3%85%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%205.95pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%E8%BF%9E%E6%8E%A5%E4%BC%A0%E6%84%9F%E5%99%A8%E7%94%B5%E6%BA%90%3CSPAN%20style%3D%22background-position%3A%20initial%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%E5%B0%86%20Kinect%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20NXP%20%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%EF%BC%88%E4%BD%BF%E7%94%A8%3CEM%3Elsusb%3C%2FEM%3E%E6%A3%80%E6%9F%A5%EF%BC%89%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%E5%AF%B9%E4%BA%8E%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14595451158968740%20jive_text_macro%22%20data-renderedposition%3D%222781.1806640625_50.000003814697266_1158_62%22%20jivemacro_uid%3D%22_14595451158968740%22%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3Eimx6q%40imx6q%3A~%2Fdevel%24%20lsusb%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%80%BB%E7%BA%BF%20001%20%E8%AE%BE%E5%A4%87%20022%EF%BC%9AID%20045e%3A02ae%20Microsoft%20Corp.%20Xbox%20NUI%20%E6%91%84%E5%83%8F%E5%A4%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%80%BB%E7%BA%BF%20001%20%E8%AE%BE%E5%A4%87%20021%EF%BC%9AID%20045e%EF%BC%9A02ad%20Microsoft%20Corp.%20Xbox%20NUI%20%E9%9F%B3%E9%A2%91%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E6%80%BB%E7%BA%BF%20001%20%E8%AE%BE%E5%A4%87%20019%EF%BC%9AID%20045e%EF%BC%9A02c2%20Microsoft%20Corp.%20Kinect%20for%20Windows%20NUI%20%E7%94%B5%E6%9C%BA%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23444444%3B%20background%3A%20white%3B%22%3E%3CSPAN%20lang%3D%22EN-AU%22%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%23666666%3B%22%3E%E7%8E%B0%E5%9C%A8%E5%9C%A8%20Ubuntu%20%E4%B8%AD%E7%BC%96%E8%BE%91%E5%85%A8%E5%B1%80%20Kinect%20%E8%AE%BE%E7%BD%AE%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14595452005317716%22%20data-renderedposition%3D%222868.95849609375_50.000003814697266_1158_117%22%20jivemacro_uid%3D%22_14595452005317716%22%3E%3CP%20class%3D%22Code%22%3E%24%20sudo%20nano%20%2Fusr%2Fetc%2Fprimesense%2FGlobalDefaultsKinect.ini%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E5%B9%B6%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%E6%AD%A4%E8%A1%8C%0AUsbInterface%3D1%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E5%B9%B6%E5%B0%86%E5%85%B6%E6%94%B9%E4%B8%BA%201%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%202%3C%2FP%3E%3CP%20class%3D%22Code%22%3EUsbInterface%3D2%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%205.95pt%3B%20background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20sudo%20modprobe%20-r%20gspca_kinect%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23666666%3B%20background%3A%20white%3B%20font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E7%84%B6%E5%90%8E%E5%B0%86%E5%85%B6%E5%88%97%E5%85%A5%E9%BB%91%E5%90%8D%E5%8D%95%E4%BB%A5%E9%81%BF%E5%85%8D%E5%85%B6%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E8%87%AA%E5%8A%A8%E5%8A%A0%E8%BD%BD%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14595452691994794%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223011.319580078125_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14595452691994794%22%3E%3CP%3E%24%20sudo%20sh%20-c%20'echo%20%22%E9%BB%91%E5%90%8D%E5%8D%95%20gspca_kinect%22%20%26gt%3B%20%2Fetc%2Fmodprobe.d%2Fblacklist-kinect.conf'%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%E7%84%B6%E5%90%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597909864832564%20jive_text_macro%22%20data-renderedposition%3D%223052.4306640625_50.000003814697266_1158_31%22%20jivemacro_uid%3D%22_14597909864832564%22%20modifiedtitle%3D%22true%22%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20~%2Fdevel%2FOpenNI%2FPlatform%2FLinux%2FBin%2FArm-Release%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%24%20sudo%20.%2FSample-NiSimpleRead%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%BE%97%E5%88%B0%E7%B1%BB%E4%BC%BC%E8%BF%99%E6%A0%B7%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597910155028364%20jive_text_macro%22%20data-renderedposition%3D%223109.097412109375_50.000003814697266_1158_171%22%20jivemacro_uid%3D%22_14597910155028364%22%3E%3CP%20class%3D%22Code%22%3E%E6%AD%A3%E5%9C%A8%E4%BB%8E%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E8%AF%BB%E5%8F%96%E9%85%8D%E7%BD%AE%EF%BC%9A%E2%80%9C..%2F..%2F..%2F..%2FData%2FSamplesConfig.xml%E2%80%9D%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E2%80%A6%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2040%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.771788%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2041%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.866173%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2042%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.850958%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2043%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.779032%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2044%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.767746%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2045%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.800463%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2046%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.653118%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2047%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.741659%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%E7%AC%AC%2098%20%E5%B8%A7%E4%B8%AD%E9%97%B4%E7%82%B9%E6%98%AF%EF%BC%9A5050%E3%80%82%E6%AF%8F%E7%A7%92%E5%B8%A7%E6%95%B0%EF%BC%9A30.339321%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ELibFreenect%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14597910672264130%20jive_text_macro%22%20data-renderedposition%3D%223331.319580078125_50.000003814697266_1158_124%22%20jivemacro_uid%3D%22_14597910672264130%22%3E%3CP%20class%3D%22Code%22%3E%24%20cd%20~%2Fdevel%2F%3C%2FP%3E%3CP%20class%3D%22Code%22%3E%3CSPAN%3E%24%20git%20clone%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fgithub.com%252FOpenKinect%252Flibfreenect.git%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fgithub.com%2FOpenKinect%2Flibfreenect.git%3C%2FA%3E%20%24%20cd%20libfreenect%0A%20%24%20mkdir%20%E6%9E%84%E5%BB%BA%0A%24%20cd%20%E6%9E%84%E5%BB%BA%3CSPAN%20style%3D%22color%3A%20%23666666%3B%20background%3A%20white%3B%22%3E%20%24%20cmake%20..%20%E2%80%93L%20%E2%80%93DBUILD_AUDIO%3DON%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23666666%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%20%24%20make%3C%2FSPAN%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%20%24%20sudo%20make%20install%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1851206732%22%20style%3D%22background%3A%20white%3B%22%20id%3D%22toc-hId--1851206732%22%20id%3D%22toc-hId--930576481%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%20font-weight%3A%20normal%3B%22%3E%E8%BF%9E%E6%8E%A5%20Kinect%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%94%B5%E6%BA%90%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%20color%3A%20%23666666%3B%20font-weight%3A%20normal%3B%20background-position%3A%20initial%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%23666666%3B%20font-weight%3A%20normal%3B%22%3E%E5%B0%86%20Kinect%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20NXP%20%E6%9D%BF%20USB%20%E7%AB%AF%E5%8F%A3%E5%B9%B6%3CSPAN%20style%3D%22background-position%3A%20initial%3B%22%3E%E6%B5%8B%E8%AF%95%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14597911076822457%22%20data-renderedposition%3D%223506.875244140625_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597911076822457%22%3E%3CP%3E%3CSPAN%20style%3D%22background%3A%20white%3B%22%3E%24%20sudo%20freenect-glview%3C%2FSPAN%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F27684i95F6FE12BB9EFF8A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20background%3A%20white%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%E5%A6%82%E6%9E%9C%20glview%20%E7%BB%99%E5%87%BA%E5%85%B1%E4%BA%AB%E5%BA%93%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.8pt%3B%20margin-bottom%3A%206.0pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%88%B7%E6%96%B0%20ldconfig%20%E7%BC%93%E5%AD%98%E3%80%82%E6%9C%80%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%20usr-local-libs.conf%EF%BC%88%E6%88%96%E4%BB%BB%E4%BD%95%E6%82%A8%E5%B8%8C%E6%9C%9B%E7%9A%84%E5%90%8D%E7%A7%B0%EF%BC%89%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597911469294966%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223914.687744140625_50.000003814697266_1158_16%22%20jivemacro_uid%3D%22_14597911469294966%22%3E%3CPRE%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%2Fusr%2Flocal%2Flib%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-top%3A%204.8pt%3B%20margin-bottom%3A%206.0pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%E5%88%87%E6%8D%A2%E5%88%B0root%E5%B8%90%E6%88%B7%E5%B9%B6%E5%B0%86%E5%85%B6%E7%A7%BB%E5%8A%A8%E5%88%B0%2Fetc%2Fld.so.conf.d%2Fusr-local-libs.conf%E3%80%82%E7%84%B6%E5%90%8E%E6%9B%B4%E6%96%B0%20ldconfig%20%E7%BC%93%E5%AD%98%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14597911701927071%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223979.791748046875_50.000003814697266_1158_98%22%20jivemacro_uid%3D%22_14597911701927071%22%3E%3CPRE%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%24%20su%20root%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%24%20mv%20~%2Fusr-local-libs.conf%20%2Fetc%2Fld.so.conf.d%2Fusr-local-libs.conf%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%24%20%2Fsbin%2Fldconfig%20%E2%80%93v%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22background-position%3A%20initial%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20black%3B%22%3E%24%E9%80%80%E5%87%BA%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CP%20style%3D%22margin-top%3A%204.8pt%3B%20margin-bottom%3A%206.0pt%3B%20background%3A%20white%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-top%3A%204.8pt%3B%20margin-bottom%3A%206.0pt%3B%20background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%22%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E1%EF%BC%89%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fopenkinect.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fopenkinect.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fopenkinect.org%2F%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E2)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.asus.com%2Fus%2F3D-Sensor%2FXtion_PRO_LIVE%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.asus.com%2Fus%2F3D-Sensor%2FXtion_PRO_LIVE%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fwww.asus.com%2Fus%2F3D-Sensor%2FXtion_PRO_LIVE%2F%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E3%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%20Lentin%20Joseph%20%E7%9A%84%20phyton%20%E5%AD%A6%E4%B9%A0%E6%9C%BA%E5%99%A8%E4%BA%BA%E6%8A%80%E6%9C%AF%E3%80%82%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.amazon.com%2FLearning-Robotics-Python-Lentin-Joseph%2Fdp%2F1783287535%2Fref%3Dsr_1_1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22http%3A%2F%2Fwww.amazon.com%2FLearning-Robotics-Python-Lentin-Joseph%2Fdp%2F1783287535%2Fref%3Dsr_1_1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22test_blank%22%3Ehttp%3A%2F%2Fwww.amazon.com%2FLearning-Robotics-Python-Lentin-Joseph%2Fdp%2F1783287535%2Fref%3Dsr_1_1%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20calibri%2C%20verdana%2C%20arial%2C%20sans-serif%3B%22%3E4%EF%BC%89%20%3CA%20href%3D%22http%3A%2F%2Fimxcv.blogspot.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fimxcv.blogspot.com%2F%22%20target%3D%22_blank%22%3Ei.MX%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%8A%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E8%A7%86%E8%A7%89%3C%2FA%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎09-10-2020 03:36 AM
更新人:
