GStreamer i.MX6 Image Display
There is no Freescale GStreamer element which does the JPEG decoding, so we must rely on a standard one, like 'jpegdec'. In case your Linux system was built using LTIB, in order to have the jpegdec element included on the gst-plugin-good, follow these steps:
  1. On the LTIB menuconfig, make sure the following packages are selected:
    1. gstreamer-plugins-good
    2. libjpeg
    3. libpng
  2. Remove the configure parameters '--disbale-libpng' and '--disable-jpeg' on the file './dist/lfs-5.1/gst-plugins-good/gst-plugins-good.spec'
  3. Rebuild and flash your board (or SD card) again.
Image displayVSALPHA=1 gst-launch filesrc location=sample.jpeg ! jpegdec ! imagefreeze ! mfw_isink
Important: non 8 pixel aligned width and height is treated as not supported format in isink plugin.
ラベル(4)
コメント
Hi Leonardo,
Have you tried this command on i.MX6Q Ubuntu?
It's not working for me.
Tarek
Hi Tarek,
I have not tried it on Ubuntu. Do you see an error on the pipeline's log?
My apologies .... I'm using different sink
gst-launch filesrc location=f18.jpeg ! jpegdec ! imagefreeze ! mfw_v4lsink
So it only works for mfw_isink
I see. Thanks for the clarification. BTW, I need to investigate why the v4lsink case is not working for this particular case.
On L3.0.35 4.0.0, there may be issues when rending high resolution images (>1080) on HDMI. If image rendering looks bad (instead of just one image, there are several columns and some noise at the central area of the monitor), please apply the following patch on kernel
From 6ae2813aed1063143400de8fe111a9d9a6130a4a Mon Sep 17 00:00:00 2001
Date: Wed, 24 Jul 2013 00:20:26 -0500
Subject: [PATCH] ENGR00272541 [IPU] -  IC_RSZ_MAX_RESIZE_RATIO should be set
to 0x2000
The max resize ratio should be set to 0x2000 (or 8192).
Signed-off-by: Oliver Brown <b37094@b37094-vmlinux.(none)>
drivers/mxc/ipu3/ipu_regs.h |    2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
mode change 100644 => 100755 drivers/mxc/ipu3/ipu_regs.h
diff --git a/drivers/mxc/ipu3/ipu_regs.h b/drivers/mxc/ipu3/ipu_regs.h
old mode 100644
new mode 100755
index 94c587e..f089f7d
--- a/drivers/mxc/ipu3/ipu_regs.h
+++ b/drivers/mxc/ipu3/ipu_regs.h
@@ -465,7 +465,7 @@ enum {
     IC_CONF_RWS_EN = 0x40000000,
     IC_CONF_CSI_MEM_WR_EN = 0x80000000,
-    IC_RSZ_MAX_RESIZE_RATIO = 0x00004000,
+    IC_RSZ_MAX_RESIZE_RATIO = 0x00002000,
     IC_IDMAC_1_CB0_BURST_16 = 0x00000001,
     IC_IDMAC_1_CB1_BURST_16 = 0x00000002,
1.7.9.5
HI
How to fixed following warning while trying to display image using VSALPHA=1 gst-launch filesrc location=sample.jpeg ! jpegdec ! imagefreeze ! mfw_isink.
WARNING: erroneous pipeline: no element "imagefreeze"
Make sure yo have gst-plugins-good installed on your system
Tarek
gst-plugins-good was missing, after adding it issue is resolved.
Saurabh
%3CLINGO-SUB%20id%3D%22lingo-sub-1118590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGStreamer%20i.MX6%20%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EJPEG%E3%83%87%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A1%8C%E3%81%86Freescale%20GStreamer%E8%A6%81%E7%B4%A0%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%80%8C%3CSTRONG%3E%3CEM%3Ejpegdec%3C%2FEM%3E%3C%2FSTRONG%3E%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%A8%99%E6%BA%96%E3%81%AE%E8%A6%81%E7%B4%A0%E3%81%AB%E9%A0%BC%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Linux%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8CLTIB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%3CEM%3Egst-plugin-good%3C%2FEM%3E%E3%81%AB%3CEM%3Ejpegdec%3C%2FEM%3E%E8%A6%81%E7%B4%A0%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3ELTIB%20menuconfig%20%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3COL%3E%3CLI%3Egstreamer-plugins-%E8%89%AF%E3%81%84%3C%2FLI%3E%3CLI%3E%3CEM%3Elibjpeg%3C%2FEM%3E%3C%2FLI%3E%3CLI%3E%3CEM%3Elibpng%3C%2FEM%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20'%3CEM%3E.%2Fdist%2Flfs-5.1%2Fgst-plugins-good%2Fgst-plugins-good.spe%3C%2FEM%3Ec'%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20'%3CEM%3E--disbale-libpn%3C%2FEM%3Eg'%20%E3%81%A8%20%3CEM%3E'--disable-jpeg%3C%2FEM%3E'%20%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%9C%E3%83%BC%E3%83%89(%E3%81%BE%E3%81%9F%E3%81%AFSD%E3%82%AB%E3%83%BC%E3%83%89)%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20class%3D%22jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20width%3A%20100%25%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3CTH%20style%3D%22text-align%3A%20center%3B%20background-color%3A%20%236690bc%3B%20color%3A%20%23ffffff%3B%20padding%3A%202px%3B%22%20valign%3D%22middle%22%3E%3C%2FTH%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E%3CSTRONG%3E%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%3CSTRONG%3EVSALPHA%3D1%20gst-launch%20filesrc%20location%3Dsample.jpeg%20!JPEGDEC%E3%81%AE%20!%E7%94%BB%E5%83%8F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA!mfw_isink%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22padding%3A%202px%3B%22%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%87%8D%E8%A6%81%3A%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E8%20%E3%83%94%E3%82%AF%E3%82%BB%E3%83%AB%E4%BB%A5%E5%A4%96%E3%81%AE%E5%B9%85%E3%81%A8%E9%AB%98%E3%81%95%E3%81%AF%E3%80%81isink%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%BD%A2%E5%BC%8F%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3ETarek%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egst-plugins-good%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%BF%BD%E5%8A%A0%E5%BE%8C%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%A9%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%ABgst-plugins-good%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHI%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EVSALPHA%3D1%20gst-launch%20filesrc%20location%3Dsample.jpeg%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%BB%E5%83%8F%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AE%E6%AC%A1%E3%81%AE%E8%AD%A6%E5%91%8A%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95JPEGDEC%E3%81%AE%20!%E7%94%BB%E5%83%8F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA!mfw_isink%E3%80%82%3C%2FP%3E%3CP%3E%E8%AD%A6%E5%91%8A%3A%E8%AA%A4%E3%81%A3%E3%81%9F%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%3A%E8%A6%81%E7%B4%A0%E3%80%8Cimagefreeze%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EL3.0.35%204.0.0%20%E3%81%A7%E3%81%AF%E3%80%81HDMI%E3%81%A7%E9%AB%98%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%81%AE%E7%94%BB%E5%83%8F(%26gt%3B1080)%E3%82%92%E3%83%AA%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E6%82%AA%E3%81%8F%E8%A6%8B%E3%81%88%E3%82%8B%E5%A0%B4%E5%90%88%20(1%20%E3%81%A4%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%E3%81%AE%E4%B8%AD%E5%A4%AE%E9%A0%98%E5%9F%9F%E3%81%AB%E8%A4%87%E6%95%B0%E3%81%AE%20%3CEM%3E%E5%88%97%3C%2FEM%3E%20%E3%81%A8%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88)%20%E3%81%AF%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EFrom%206ae2813aed1063143400de8fe111a9d9a6130a4a%20Mon%20Sep%2017%2000%3A00%3A00%202001%3C%2FP%3E%0A%3CP%3E%E5%B7%AE%E5%87%BA%E4%BA%BA%3A%20Oliver%20Brown%20%3CB37094%3E%3C%2FB37094%3E%3C%2FP%3E%0A%3CP%3E%E6%97%A5%E4%BB%98%3A%202013%E5%B9%B47%E6%9C%8824%E6%97%A5(%E6%B0%B4)%2000%3A20%3A26%20-0500%3C%2FP%3E%0A%3CP%3E%E4%BB%B6%E5%90%8D%3A%20%5BPATCH%5D%20ENGR00272541%20%5BIPU%5D%20-%20IC_RSZ_MAX_RESIZE_RATIO%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%200x2000%E3%81%B8%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%A4%A7%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%E6%AF%94%E7%8E%87%E3%81%AF%200x2000%20(%E3%81%BE%E3%81%9F%E3%81%AF%208192)%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E7%BD%B2%E5%90%8D%E8%80%85%3A%20Oliver%20Brown%20%3CB37094%3E%3C%2FB37094%3E%3C%2FP%3E%0A%3CP%3E---%3C%2FP%3E%0A%3CP%3E%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%2FMXC%2FIPU3%2Fipu_regs.h%20%7C%26nbsp%3B%26nbsp%3B%202%20%2B-%3C%2FP%3E%0A%3CP%3E%201%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%A4%89%E6%9B%B4%E3%80%811%20%E6%8C%BF%E5%85%A5(%2B)%E3%80%811%20%E5%89%8A%E9%99%A4(-)%3C%2FP%3E%0A%3CP%3E%20%E3%83%A2%E3%83%BC%E3%83%89%E5%A4%89%E6%9B%B4%20100644%20%3D%26gt%3B%20100755%20drivers%2Fmxc%2Fipu3%2Fipu_regs.h%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%E5%B7%AE%E5%88%86%20--git%20a%2Fdrivers%2Fmxc%2Fipu3%2Fipu_regs.hb%2Fdrivers%2Fmxc%2Fipu3%2Fipu_regs.h%3C%2FP%3E%0A%3CP%3E%E6%97%A7%E3%83%A2%E3%83%BC%E3%83%89100644%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%83%A2%E3%83%BC%E3%83%89100755%3C%2FP%3E%0A%3CP%3E%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B994C587E.%E3%80%82F089F7D%E3%81%AE%3C%2FP%3E%0A%3CP%3E---%20a%2Fdrivers%2Fmxc%2Fipu3%2Fipu_regs.h%3C%2FP%3E%0A%3CP%3E%2B%2B%2B%20b%2Fdrivers%2Fmxc%2Fipu3%2Fipu_regs.h%3C%2FP%3E%0A%3CP%3E%40%40%20-465%2C7%20%2B465%2C7%20%40%40%20%E5%88%97%E6%8C%99%E5%9E%8B%20%7B%3C%2FP%3E%0A%3CP%3EIC_CONF_RWS_EN%20%3D%200x40000000%E3%80%81%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IC_CONF_CSI_MEM_WR_EN%20%3D%200x80000000%2C%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E-%20IC_RSZ_MAX_RESIZE_RATIO%20%3D%200x00004000%E3%80%81%3C%2FP%3E%0A%3CP%3E%2B%20IC_RSZ_MAX_RESIZE_RATIO%20%3D%200x00002000%E3%80%81%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IC_IDMAC_1_CB0_BURST_16%20%3D%200x00000001%2C%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20IC_IDMAC_1_CB1_BURST_16%20%3D%200x00000002%2C%3C%2FP%3E%0A%3CP%3E--%20%3C%2FP%3E%0A%3CP%3E1.7.9.5%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AA%E3%82%8B%E3%81%BB%E3%81%A9%E3%80%82%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7v4lsink%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%82%92%E8%AA%BF%E6%9F%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93...%E3%80%82%E7%A7%81%E3%81%AF%E5%88%A5%E3%81%AE%E3%82%B7%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGST-%E3%83%AD%E3%83%BC%E3%83%B3%E3%83%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABRC%20location%3Df18.jpeg%20!JPEGDEC%E3%81%AE%20!%E7%94%BB%E5%83%8F%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA!mfw_v4lsink%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%81%9D%E3%82%8C%E3%81%AFmfw_isink%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%A0%E3%81%91%E5%83%8D%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tarek%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUbuntu%E3%81%A7%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%91%E3%82%A4%E3%83%97%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1118591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AGStreamer%20i.MX6%E7%94%BB%E5%83%8F%E8%A1%A8%E7%A4%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Leonardo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92i.MX6Q%20Ubuntu%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AB%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ETarek%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-15-2012 09:01 AM
更新者:
