FreeBSD on i.MX6
FreeBSD on i.MX6
FreeBSD on i.MX6
Starting with a quad-core wandboard. Download a wandboard image
~/freebsd$ wget ftp://ftp.freebsd.org/pub/FreeBSD/snapshots/arm/armv6/ISO-IMAGES/11.4/FreeBSD-11.4-CURRENT-arm-armv6...
Unzip it
~/freebsd$ bunzip2 FreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img.bz2
Copy it to a microSD card (assuming the SD card shows up at /dev/sdb)
~/freebsd$ sudo dd if=FreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img of=/dev/sdb bs=1M
Insert into a wandboard-quad with serial console connected through a NULL modem (1152008N1)
The root user has no password.
If you had an ethernet cable plugged in you should get a dhcp address.
A nice feature is that the filesystem got expanded to fill the SD card during the first boot.
root@wandboard:~ # df -h
Filesystem        Size    Used   Avail Capacity  Mounted on
/dev/mmcsd0s2a     14G    403M     13G     3%    /
devfs             1.0K    1.0K      0B   100%    /dev
/dev/mmcsd0s1      50M    260K     50M     1%    /boot/msdos
tmpfs              30M    4.0K     30M     0%    /tmp
tmpfs              15M     52K     15M     0%    /var/log
tmpfs             5.0M    4.0K    5.0M     0%    /var/tmp
Not much running other then dhclient(8) and sshd(8).
root@wandboard:~ # ps -ax
PID TT  STAT      TIME COMMAND
  0  -  DLs    0:00.01 [kernel]
  1  -  ILs    0:00.04 /sbin/init --
  2  -  DL     0:00.00 [cam]
  3  -  DL     0:00.00 [sctp_iterator]
  4  -  DL     0:00.04 [mmcsd0: mmc/sd card]
  5  -  DL     0:00.05 [pagedaemon]
  6  -  DL     0:00.00 [vmdaemon]
  7  -  DL     0:00.00 [pagezero]
  8  -  DL     0:00.04 [bufdaemon]
  9  -  DL     0:00.01 [vnlru]
 10  -  RL   128:27.66 [idle]
 11  -  WL     0:01.53 [intr]
 12  -  DL     0:00.10 [geom]
 13  -  DL     0:00.18 [rand_harvestq]
 14  -  DL     0:00.04 [usb]
 15  -  DL     0:00.04 [syncer]
259  -  Is     0:00.02 /sbin/devd
278  -  Is     0:00.01 dhclient: ffec0 [priv] (dhclient)
396  -  Is     0:00.01 dhclient: ffec0 (dhclient)
499  -  Is     0:00.02 casperd: zygote (casperd)
500  -  Is     0:00.03 /sbin/casperd
704  -  Is     0:00.02 /usr/sbin/sshd
705  -  Ss     0:00.24 sshd: root@pts/0 (sshd)
643 u0  Is     0:00.05 login [pam] (login)
644 u0  I+     0:00.13 -csh (csh)
709  0  Ss     0:00.10 -csh (csh)
729  0  R+     0:00.01 ps -ax
SSH Login
A running sshd(8) server is a nice convenience since it’s usually the first thing I install on Linux systems.
If you didn’t want sshd(8) running at startup, you would change this line in rc.conf(5) in /etc
sshd_enable="YES"
Root logins over ssh are not allowed by default.
To get in with root, you can do this
  1. Add a password to root
  2. Edit /etc/ssh/sshd_config to PermitRootLogin yes
  3. Then restart sshd.
root@wandboard:~ # service sshd restart
And you should be able to log in over ssh in as root.
Or you could add another non-root user.
Date/time
Set the timezone
root@wandboard:~ # cp /usr/share/zoneinfo/EST5EDT /etc/localtime
Since the wandboards have no battery backup for system time, we’ll want to start an ntpd(8) daemon. To do this add some entries to the rc.conf(5) file
ntpd_enable="YES"
ntpd_sync_on_start="YES"
And start the service
root@wandboard:~ # service ntpd start
Because there is no battery backup, the first update to the clock will likely be larger then 1000 seconds. This is too much of an offset for ntpd(8) and will cause it to shutdown. The ntpd_sync_on_start setting adds the -g flag to the ntpd(8) arguments to allow ntpd(8) to perform a onetime, very large update at startup.
You can remove the line for ntpdate(8). The service is being retired.
Static IP
If you wanted a static ipv4 address, you could make the following changes to rc.conf(5)
- ifconfig_ffec0="DHCP"
+ ifconfig_ffec0="inet <address> netmask <netmask>"
+ defaultrouter="<default router address>"
For example
ifconfig_ffec0="inet 192.168.10.21 netmask 255.255.255.0"
defaultrouter="192.168.10.2"
And then you’ll probably also want to add an entry in resolv.conf(5) for DNS. Here’s an example for my internal lan
root@wandboard:~ # cat /etc/resolv.conf
search jumpnow
nameserver 192.168.10.2
The ffec0 portion of that ifconfig_ffec0 entry comes from the kernel driver name for the ethernet adapter. You can see the name with ifconfig(8)
root@wandq2:~ # ifconfig -a
ffec0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=80008<VLAN_MTU,LINKSTATE>
        ether 00:1f:7b:b4:03:79
        inet 192.168.10.21 netmask 0xffffff00 broadcast 192.168.10.255
        media: Ethernet autoselect (1000baseT <full-duplex,master>)
        status: active
        nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
        inet 127.0.0.1 netmask 0xff000000
        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
You have the FreeBSD on a i.MX6Q
%3CLINGO-SUB%20id%3D%22lingo-sub-1174002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6%20%E4%B8%8A%E3%81%AE%20FreeBSD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1174002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CP%3E%E3%82%AF%E3%82%A2%E3%83%83%E3%83%89%E3%82%B3%E3%82%A2%3CA%20href%3D%22http%3A%2F%2Fwww.wandboard.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%E3%81%8B%E3%82%89%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3CEM%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%3C%2FEM%3E%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3E~%2Ffreebsd%24%20wget%20%3CA%20href%3D%22ftp%3A%2F%2Fftp.freebsd.org%2Fpub%2FFreeBSD%2Fsnapshots%2Farm%2Farmv6%2FISO-IMAGES%2F11.4%2FFreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img.bz2%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eftp%3A%2F%2Fftp.freebsd.org%2Fpub%2FFreeBSD%2Fsnapshots%2Farm%2Farmv6%2FISO-IMAGES%2F11.4%2FFreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img.bz2%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EUnzip%20it%3C%2FP%3E%0A%3CP%3E~%2Ffreebsd%24%20bunzip2%20FreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img.bz2%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92microSD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99(SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%20%3CEM%3E%2F%20dev%20%2F%20sdb%3C%2FEM%3E%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99)%3C%2FP%3E%0A%3CP%3E~%2Ffreebsd%24%20sudo%20dd%20if%3DFreeBSD-11.4-CURRENT-arm-armv6-WANDBOARD-QUAD.img%20of%3D%2Fdev%2Fsdb%20bs%3D1M%3C%2FP%3E%0A%3CP%3ENULL%E3%83%A2%E3%83%87%E3%83%A0%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E4%BB%98%E3%81%8D%E3%81%AE%20%3CEM%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%AF%E3%83%AF%E3%83%83%E3%83%89%3C%2FEM%3E%20%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%97%E3%81%BE%E3%81%99(1152008N1)%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eroot%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CEM%3Edhcp%3C%2FEM%3E%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%84%AA%E3%82%8C%E3%81%9F%E6%A9%9F%E8%83%BD%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8CSD%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E3%81%84%E3%81%A3%E3%81%B1%E3%81%84%E3%81%AB%E6%8B%A1%E5%BC%B5%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20df%20-h%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%E6%B8%88%E3%81%BF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%20%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E5%AE%B9%E9%87%8F%E3%81%8C%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%2Fdev%2Fmmcsd0s2a%2014G%20403M%2013G%203%25%20%2F%3C%2FP%3E%0A%3CP%3Edevfs%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.0K%26nbsp%3B%26nbsp%3B%26nbsp%3B%201.0K%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200B%26nbsp%3B%26nbsp%3B%20100%25%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fdev%3C%2FP%3E%0A%3CP%3E%2Fdev%2Fmmcsd0s1%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2050M%26nbsp%3B%26nbsp%3B%26nbsp%3B%20260K%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2050M%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%201%25%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fboot%2Fmsdos%3C%2FP%3E%0A%3CP%3Etmpfs%2030M%204.0K30M%200%25%2Ftmp%3C%2FP%3E%0A%3CP%3Etmpfs%2015M%2052K%2015M%200%25%20%2Fvar%2Flog%3C%2FP%3E%0A%3CP%3Etmpfs%205.0M4.0K%20%E9%96%B2%E8%A6%A7%E6%95%B05.0M%20%E9%96%B2%E8%A6%A7%E6%95%B00%25%20%2Fvar%2Ftmp%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dsshd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Edhclient(8)%3C%2FA%3E%20%E3%81%A8%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dsshd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esshd(8)%3C%2FA%3E%20%E4%BB%A5%E5%A4%96%E3%81%AF%E3%81%82%E3%81%BE%E3%82%8A%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20ps%20-ax%3C%2FP%3E%0A%3CP%3EPID%20TT%20STAT%20TIME%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%200%26nbsp%3B%20-%26nbsp%3B%20DLs%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3A00.01%20%5Bkernel%5D%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%201%26nbsp%3B%20-%26nbsp%3B%20ILs%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3A00.04%20%2Fsbin%2Finit%20--%3C%2FP%3E%0A%3CP%3E2%20-%20DL%200%3A00.00%20%5B%E3%82%AB%E3%83%A1%E3%83%A9%5D%3C%2FP%3E%0A%3CP%3E3%20-%20DL%200%3A00.00%20%5Bsctp_iterator%5D%3C%2FP%3E%0A%3CP%3E4%20-%20DL%200%3A00.04%20%5Bmmcsd0%3A%20mmc%2Fsd%20%E3%82%AB%E3%83%BC%E3%83%89%5D%3C%2FP%3E%0A%3CP%3E5%20-%20DL%200%3A00.05%20%5B%E3%83%9A%E3%83%BC%E3%82%B8%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%5D%3C%2FP%3E%0A%3CP%3E6%20-%20DL%200%3A00.00%20%5Bvmdaemon%5D%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%207%26nbsp%3B%20-%26nbsp%3B%20DL%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3A00.00%20%5Bpagezero%5D%3C%2FP%3E%0A%3CP%3E8%20-%20DL%200%3A00.04%20%5Bbufdaemon%5D%3C%2FP%3E%0A%3CP%3E9%20-%20DL%200%3A00.01%20%5Bvnlru%5D%3C%2FP%3E%0A%3CP%3E10%20-%20RL%20128%3A27.66%20%5B%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%5D%3C%2FP%3E%0A%3CP%3E11%20-%20WL%200%3A01.53%20%5B%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%AB%5D%3C%2FP%3E%0A%3CP%3E12%20-%20DL%200%3A00.10%20%5B%E3%82%B8%E3%82%AA%E3%83%A0%5D%3C%2FP%3E%0A%3CP%3E13%20-%20DL%200%3A00.18%20%5Brand_harvestq%5D%3C%2FP%3E%0A%3CP%3E14%20-%20DL%200%3A00.04%20%5BUSB%5D%3C%2FP%3E%0A%3CP%3E15%20-%20DL%200%3A00.04%20%5B%E3%82%B7%E3%83%B3%E3%82%AB%E3%83%BC%5D%3C%2FP%3E%0A%3CP%3E259%20-%200%3A00.02%20%2Fsbin%2Fdevd%20%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E278%20-%200%3A00.01%20dhclient%3A%20ffec0%20%5Bpriv%5D%20(dhclient)%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E396%20-%20Is%200%3A00.01%20dhclient%3A%20ffec0%20(dhclient)%3C%2FP%3E%0A%3CP%3E499%20-%20Is%200%3A00.02%20casperd%3A%20zygote%20(casperd)%3C%2FP%3E%0A%3CP%3E500%20-%200%3A00.03%20%2Fsbin%2Fcasperd%20%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E704%20-%200%3A00.02%20%2F%20usr%20%2F%20sbin%20%2F%20sshd%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E705%20-%20SS%200%3A00.24%20sshd%3A%20root%40pts%2F0%20(sshd)%3C%2FP%3E%0A%3CP%3E643%20u0%20Is%200%3A00.05%20login%20%5Bpam%5D%20(%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3)%3C%2FP%3E%0A%3CP%3E644%20u0%26nbsp%3B%20I%2B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3A00.13%20-csh%20(csh)%3C%2FP%3E%0A%3CP%3E709%26nbsp%3B%200%26nbsp%3B%20Ss%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200%3A00.10%20-csh%20(csh)%3C%2FP%3E%0A%3CP%3E729%200%20R%20%2B%200%3A00.01%20ps%20-ax%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ESSH%20Login%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dsshd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%20sshd(8)%3C%2FA%3E%20%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AF%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81%E7%A7%81%E3%81%8C%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E6%9C%80%E5%88%9D%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%A8%E3%81%A6%E3%82%82%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dsshd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esshd(8)%3C%2FA%3E%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%2Fetc%20%E3%81%AE%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Drc.conf%26amp%3Bapropos%3D0%26amp%3Bsektion%3D5%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Erc.conf(5)%3C%2FA%3E%20%E3%81%AE%E3%81%93%E3%81%AE%E8%A1%8C%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3Esshd_enable%3D%22%E3%81%AF%E3%81%84%22%3C%2FP%3E%0A%3CP%3E%3CEM%3Essh%3C%2FEM%3E%20%E7%B5%8C%E7%94%B1%E3%81%AE%20root%20%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3Eroot%E3%81%A7%E5%8F%82%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3Eroot%20%E3%81%AB%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3E%2Fetc%2Fssh%2Fsshd_config%20%E3%82%92%20%3CEM%3EPermitRootLogin%20yes%3C%2FEM%3E%20%E3%81%AB%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81sshd%20%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20sshd%20restart%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CEM%3Essh%E7%B5%8C%E7%94%B1%E3%81%A7root%3C%2FEM%3E%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E5%88%A5%E3%81%AE%E9%9D%9E%20root%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E6%97%A5%E4%BB%98%2F%E6%99%82%E5%88%BB%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%BE%E3%83%BC%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20cp%20%2Fusr%2Fshare%2Fzoneinfo%2FEST5EDT%20%2Fetc%2Flocaltime%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E3%83%AF%E3%83%B3%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%3C%2FEM%3E%E3%81%AB%E3%81%AF%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E6%99%82%E9%96%93%E7%94%A8%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dntpd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Entpd(8)%3C%2FA%3E%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Drc.conf%26amp%3Bapropos%3D0%26amp%3Bsektion%3D5%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Erc.conf(5)%3C%2FA%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3Entpd_enable%3D%22%E3%81%AF%E3%81%84%22%3C%2FP%3E%0A%3CP%3Entpd_sync_on_start%3D%22%E3%81%AF%E3%81%84%22%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E9%96%8B%E5%A7%8B%3C%2FP%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%20ntpd%20start%3C%2FP%3E%0A%3CP%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AF%20%3CEM%3E1000%20%E7%A7%92%3C%2FEM%3E%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%8F%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20ntpd(8)%20%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%99%E3%81%8E%E3%81%A6%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dntpd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Entpd(8)%3C%2FA%3E%20%E3%82%92%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%81%95%E3%81%9B%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82ntpd_sync_on_start%20%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dntpd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Entpd(8)%3C%2FA%3E%20%E3%81%AE%E5%BC%95%E6%95%B0%E3%81%AB%20-g%20%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dntpd%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Entpd(8)%3C%2FA%3E%20%E3%81%8C%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%201%20%E5%9B%9E%E9%99%90%E3%82%8A%E3%81%AE%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%AA%E6%9B%B4%E6%96%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dntpdate%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Entpdate(8)%3C%2FA%3E%20%E3%81%AE%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AF%E5%BB%83%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E9%9D%99%E7%9A%84IP%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CEM%3E%E9%9D%99%E7%9A%84%3C%2FEM%3E%E3%81%AA%20ipv4%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Drc.conf%26amp%3Bapropos%3D0%26amp%3Bsektion%3D5%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Erc.conf(5)%3C%2FA%3E%20%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20ifconfig_ffec0%3D%22DHCP%22%3C%2FP%3E%0A%3CP%3E%2B%20ifconfig_ffec0%3D%22inet%3CADDRESS%3E%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%3CNETMASK%3E%20%22%3C%2FNETMASK%3E%3C%2FADDRESS%3E%3C%2FP%3E%0A%3CP%3E%2B%20defaultrouter%3D%22%3CDEFAULT%20router%3D%22%22%20address%3D%22%22%3E%20%22%3C%2FDEFAULT%3E%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%3C%2FP%3E%0A%3CP%3Eifconfig_ffec0%3D%E3%80%8Cinet%20192.168.10.21%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%20255.255.255.0%E3%80%8D%3C%2FP%3E%0A%3CP%3Edefaultrouter%3D%22192.168.10.2%22%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%20%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Dresolv.conf%26amp%3Bapropos%3D0%26amp%3Bsektion%3D5%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eresolv.conf(5)%3C%2FA%3E%20%E3%81%AB%E3%82%82%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CEM%3EDNS%3C%2FEM%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%86%85%E9%83%A8LAN%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3Eroot%40wandboard%3A~%20%23%20cat%20%2Fetc%2Fresolv.conf%3C%2FP%3E%0A%3CP%3E%E6%A4%9C%E7%B4%A2%20jumpnow%3C%2FP%3E%0A%3CP%3E%E3%83%8D%E3%83%BC%E3%83%A0%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%20192.168.10.2%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%20%3CEM%3Eifconfig_ffec0%3C%2FEM%3E%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AE%20%3CEM%3Effec0%3C%2FEM%3E%20%E9%83%A8%E5%88%86%E3%81%AF%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%90%8D%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.freebsd.org%2Fcgi%2Fman.cgi%3Fquery%3Difconfig%26amp%3Bapropos%3D0%26amp%3Bsektion%3D8%26amp%3Bmanpath%3DFreeBSD%2B11-current%26amp%3Barch%3Ddefault%26amp%3Bformat%3Dhtml%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eifconfig(8)%3C%2FA%3E%20%E3%81%A7%E5%90%8D%E5%89%8D%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3Eroot%40wandq2%3A~%20%23%20ifconfig%20-a%3C%2FP%3E%0A%3CP%3Effec0%3A%20flags%3D8843%3CUP%3E%20%E3%83%A1%E3%83%88%E3%83%AA%E3%83%83%E3%82%AF%200%20MTU%201500%3C%2FUP%3E%3C%2FP%3E%0A%3CP%3Eoptions%3D80008%3CVLAN_MTU%3E%3C%2FVLAN_MTU%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%BC%E3%83%86%E3%83%AB%2000%3A1F%3A7B%3AB4%3A03%3A79%3C%2FP%3E%0A%3CP%3Einet%20192.168.10.21%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xffffff00%20%E3%83%96%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%20192.168.10.255%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3A%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E8%87%AA%E5%8B%95%E9%81%B8%E6%8A%9E(1000baseT)%3C%2FP%3E%0A%3CP%3E%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%3C%2FP%3E%0A%3CP%3End6%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%2029%3C%2FP%3E%0A%3CP%3Elo0%3A%20flags%3D8049%3CUP%3E%20metric%200%20mtu%2016384%3C%2FUP%3E%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%20600003%3CRXCSUM%3E%3C%2FRXCSUM%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20inet6%20%3A%3A1%20prefixlen%20128%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20inet6%20fe80%3A%3A1%25lo0%20prefixlen%2064%20scopeid%200x2%3C%2FP%3E%0A%3CP%3Einet%20127.0.0.1%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%200xff000000%3C%2FP%3E%0A%3CP%3End6%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%3D%2021%3CPERFORMNUD%3E%3C%2FPERFORMNUD%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Ei.MX6Q%20%E3%81%AB%20FreeBSD%20%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1174002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1174002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎10-27-2020 10:42 AM
更新者:
