I've downloaded Linux imgs from this website https://cache.nxp.com/secured/bsps/LF_v5.10.72-2.2.0_images_IMX8MNEVK.zip?fileExt=.zip&__gda__=16399...
Burned with uuu tool
I can enter this command line
And the Video interface is MIPI
Here is a common documentation regarding to u-boot building:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/Building-U-boot/ta-p/1127822
Can I do this by modifying environment variables?I just want to modify the resolution through a simple way. Like ~$ set env ...
You can use saveenv u-boot option to save the changes you made with setenv.
Which variables need to be modified?
