Image Classification example of TF-lite do not use GPU on iWG27M iMX8QM kit
2,265件の閲覧回数
kushal_chaudhar
I tested  the Image classification example given in UM11226 section 7.2 On iWG27M iMX8QM SOM development kit, with Yocto ML manifest having 4.9.51 beta kernel with Opencl support.
It works fine and predicts the results in around 300 ms but it does not uses GPU. gputop application do not show any process running.
So My questions are
1) Why the application is not using GPU for its execution? (In spite of OpenCL support).
2) What needs to be done to use the GPU support.
3) I need TensorFlow-lite object detection example which utilize GPU for its execution, where Can I find that?
1,906件の閲覧回数
vanessa_maegima
Hi kushal.chaudhari@agiliad.com‌,
There's no GPU support on eIQ yet.
Vanessa
2 返答(返信)
1,906件の閲覧回数
simple_do
Hi Vanessa Maegima:
      there is example for tf-lite on  gpu run, it's avalible.
1,907件の閲覧回数
vanessa_maegima
Vanessa
