can't initial 88W8997 by PCIE
hilary_tsai
The wifi SIP module  AW-CM276NF with  88W8997 is design with CPU MT8395.
The PERST0# & W_DISABLE1 are both pulled higha and the ac coupling 100nF are used
The pcie still can't be recognized and is stock at " polling.compliance"
mtk-pcie 112f0000.pcie: PCIe link down, ltssm reg val: 0x0
[    0.907675] mtk-pcie: probe of 112f0000.pcie failed with error -110
[    0.909229] mtk-pcie 112f8000.pcie: host bridge /soc/pcie@112f8000 ranges:
[    0.910131] mtk-pcie 112f8000.pcie:       IO 0x0024000000..0x00241fffff -> 0x0024000000
[    0.911170] mtk-pcie 112f8000.pcie:      MEM 0x0024200000..0x0027ffffff -> 0x0024200000
[    1.118908] mtk-pcie 112f8000.pcie: PCIe link down, ltssm reg val: 0x2000003
[    1.119938] mtk-pcie: probe of 112f8000.pcie failed with error -110
After consulting MTK, they gauss the CPU(MT8395) doesn't get reply from 88W8997, or 88w8997 miss or not recognize the signal from CPU.
can nxp help on this issue?
Does any commend or methods to get the pcie status of 88W8997?
shaun_wu
Hello @hilary_tsai
Have you shard the schematic? The picture you shared is not very clear.
Best Regards
Shaun
hilary_tsai
Hi shaun:
the issue is fixed after I removed the AC couping cap on the tx path of WiFI module,
It seem that  the  AC couping cap is designed in module.
Thank for you support.
shaun_wu
Hello  @hilary_tsai
You could send schematic to my email addr: shaun.wu@nxp.com
Best Regards
Shaun
shaun_wu
Hello @hilary_tsai
Could you share your schematic to us?
Best Regards
Shaun
hilary_tsai
Hi shaun:
Please check it.
Besides,How can I know that the WIFI IC has started normally?
the pcie status is stock at " polling.compliance"  Does it mean the wifi ic don't send EIOS to CPU?
hilary_tsai
Hi shaun:
sure~~
However, I am not sure that I can share the schematics on the web or not.
May I get your email address and send it you by mail?
