Which timer to use for microsecond timings in JN-AN-1218-Zigbee-3-0-Light-Bulb based project
982件の閲覧回数
jacco_bezemer
I'm converting a project based on JN-AN-1171 to a project based on JN-AN-1218.
The project that i'm converting uses OS_eStartSWTimer to start a task every 78 microseconds. What timer can i use in a Zigbee 3 project?
I tried vAHI_TickTimerConfigure but it messes with the Driver_bulb timings. I can't use ZTIMER because it uses milliseconds.
968件の閲覧回数
mario_castaneda
Hi @jacco_bezemer,
You could use the next timer, but I do not know the requirements that you have
vAHI_TimerEnable
Please look at the next setup
PUBLIC void TMR_vInit(void)
 /* Make sure no DIO claimed by timer */
 vAHI_TimerDIOControl(E_AHI_TIMER_0, FALSE);
 /*Enable the Timer0*/
 vAHI_TimerEnable( E_AHI_TIMER_0,
 8, //uint8 u8Prescale,
 TRUE, //enable interupt on rising edge
 TRUE, //enable interupt on falling edge
 FALSE); //bool_t bOutputEnable);
 // Registering the callback function
 vAHI_Timer0RegisterCallback(APP_isrTimer0);
 vAHI_TimerStartRepeat( E_AHI_TIMER_0, //uint8 u8Timer,
 312, //uint16 u16Lo,
 625); //uint16 u16HI
In this code, the timer 0 interrupt is generated but not call this function at every 10ms, and also in the callback must clear the interrupt flag.
(void) u8AHI_TimerFired(E_AHI_TIMER_0);
Please let me know if you have any other questions.
Mario
3 返答(返信)
961件の閲覧回数
jacco_bezemer
Hi Mario, that makes sense.
I can see that the timer is running but no interrupt is generated. Should i change something else?
And i don't understand this sentence "the timer 0 interrupt is generated but not call this function at every 10ms"
Kind regards,
Jacco
957件の閲覧回数
jacco_bezemer
Sorry, mixed up irq_JN516x.S. Corrected it and now it works.
Thanks again Mario.
969件の閲覧回数
mario_castaneda
Hi @jacco_bezemer,
vAHI_TimerEnable
Mario
