Which debug probe to use for programming & debugging the JN5189.
523件の閲覧回数
Kunal_Gupta
I am developing the custom Eval board based on JN5189, which is breadboard compatible as my hobby project. I want to know which debug probe can be used for programming & debugging the JN5189 IC.
Would MCU link debug probe, work for programming and debugging the JN5189 IC?
What i want to achieve is like there is STM32 Blue Pill Eval Board based on STM32F103 MCU, and for that we use STLINKV2 debugger & programmer.
So is there any Debugger Programmer for NXP MCU's also?
501件の閲覧回数
EduardoZamora
Hello @Kunal_Gupta
Hope you are doing well.
MCU Link Debug Probe has been tested on JN5189 using the Carrier Main Board OM15076 and should work for your project.
Eduardo.
