I've got a USB-KW41Z and I am trying to use it via serial communication, therefore I flashed ble_fsci_blackbox.bin via Drag&Drop and tried using it via NXP Test Tool. Unfortunately I'm always receiving a FSCI-Error: gFsciUnknownOpcodeGroup_c.
So I also tried flashing bootloader_fsci_usbkw41z.bin via Drag&Drop and afterwards ble_fsci_blackbox.bin - same result.
Can someone help me getting started with ble_fsci_blackbox?
Kind regards
You could try the next command using the test tool. The command is a reset
Please let me know your findings.
Mario
i got it working - forgot flashing the initial OpenSDA-Image.
Thanks for the reply.
