Stack dump in sdk when create an attribute new from cluster basic
1,186 次查看
dangthanhnha_nt
Dear All,
I want create an attribute contain 100 byte data of cluster basic from router.
I user router is module chip jn5169, JN-AN-1217 sofware and sdk JN-SW-4170.
The step are described below:
1. I modify file basic.h in sdk:
      a. I deifine attribute: example
            #ifdef CLD_BAS_ATTR_DQ_STRING_DEVE
            #define ATTR_DQ_STRING_DEVE                              1
            #else
            #define ATTR_DQ_STRING_DEVE                              0
            #endif
      b. I define  in CLD_BASIC_NUMBER_OF_OPTIONAL_ATTRIBUTE
                   ATTR_SW_BUILD_ID                +           \
                  ATTR_DQ_TOUCH_CFG               +           \
                  ATTR_RP_GROUP_ENPOINT           +           \
                  ATTR_DQ_STRING_DEVE
      c. I define "Basic Device Information attribute set attribute ID's":
               E_CLD_BAS_ATTR_DQ_STRING_DEVE               = 0xA003
       d. I define in struct BASIC_SERVER:
               tsZCL_OctetString              sDQStringDeve;
                uint8                       au8DQStringDeve[100];
               #endif
2. I modify basic.c in sdk:
      a. I add define in #ifdef BASIC_SERVER
         {E_CLD_BAS_ATTR_DQ_STRING_DEVE,             (E_ZCL_AF_RD|E_ZCL_AF_WR),  E_ZCL_CSTRING,   (uint3            2)(&((tsCLD_Basic*)(0))->sDQStringDeve),0},
          #endif
      b. I add define
               ((tsCLD_Basic*)pvEndPointSharedStructPtr)>sDQStringDeve.u8MaxLength = sizeof(((tsCLD_Basic*)pvEndPointSharedStructPtr)->au8DQStringDeve);
               ((tsCLD_Basic*)pvEndPointSharedStructPtr)>sDQStringDeve.u8Length = 100;
                  ((tsCLD_Basic*)pvEndPointSharedStructPtr)-               >sDQStringDeve.pu8Data = ((tsCLD_Basic*)pvEndPointSharedStructPtr)->au8DQStringDeve;
             #endif
3. I add Attribte cluster into file zcl_options.h
   #define CLD_BAS_ATTR_DQ_STRING_DEVE
Question:
When I build and load file.bin into router is jn5169 it is error "Stack dump:"
File log_Stack_dump.txt is log error i print from uart after i config Enable all debug output.
Please let know the solution how to solve this error?
Thanks & Best Regards,
Nha Dang
标签 (2)
1,044 次查看
mario_castaneda
Is there any reason that you want to add this information tho the basic cluster?
You are getting a trap error caused by the b.trap instruction or the debug unit
You could create your own cluster, please look at the next community post.
ZigBee 3.0: Adding Clusters
Also, you could send a unicast taking as reference the next post https://community.nxp.com/message/1012968
Mario
1,044 次查看
dangthanhnha_nt
Hi Mario,
In any case where the stack dump is encountered, is there any notification function before that?
And I can where is check the cause? (example: Ram, Eeprom is full).
Nha Dang
1,044 次查看
mario_castaneda
Hi Dang,
You could use the stack measure files.StackMeasure.c
 vGetStackMeasure searches for the initialized value in the watermarked stack RAM area
For the EEPROM look at the app_pdm.c file
vDisplayPDMUsage()
Mario
