QN9080 reflow profile
Search instead for
benjaminchang
Contributor V
We are designing QN9080 board.
We need QN9080 reflow profile data, but cannot find it from datasheet or AN11996_QN908x Hardware Design Considerations_v13.
We searched and found related data from section 12.3 Reflow profile of QN9080-001-M17.pdf (SIP).
Can we use this SIP data for QN9080 IC, or there are other profile data? Please provide.
Benjamin
  • QN
benjaminchang
Contributor V
Hi Andrea,
Thanks for your fast response. Thank you!
Benjamin
nxf54943
Dear Benjamin Chang,
If you check the part Quality Information you can see it can support 240C° if the solder has lead or 260C°  if it is lead free, this can be check on the following link: https://www.nxp.com/part/QN9080DHN
You can also follow the Recommended Reflow Soldering Profile which can be use for this part https://www.nxp.com/docs/en/supporting-information/Reflow_Soldering_Profile.pdf
Kind regards, Andrea.
tigerzhu
We need LPC1768 reflow profile data.
benjaminchang
Contributor V
Hi Andrea,
Benjamin
