PN7642 MIFAREDesFire change key
442 次查看
artem_pn
Hello!
I`m using PN7642 to communicate with MIFAREDesFire card. I`m trying to change key using ChangeKey function. It completes successfully. But then I can`t authenticate with new key. Is there any example where keys are changed or any description of step-by-step key changing algorithm?
Thanks in advance!
Artem
标记 (1)
416 次查看
EduardoZamora
Hello @artem_pn
Hope you are doing well.
As some information about MIFARE DESFire devices is under NDA (Non-Disclosure Agreement), and therefore the information is not public, part of the documentation about these devices is located under Secure Files. Please consult the Non-Disclosure Agreement FAQs; you can try requesting an NDA directly from the NDA online form; after your request is processed, you should be contacted by the NXP NDA team.
Once you have a valid NDA, you could follow the instructions from this page: Secure Access Rights | NXP Semiconductors. Also, I would recommend checking the Secure Access Rights FAQs | NXP Semiconductors. After this, you could try requesting the relevant files from Secure Files.
Eduardo.
385 次查看
artem_pn
Hello!
Thank you for reply! I have NDA already signed and have an access to necessary documents. But still have some questions. May I ask you to advise where could I ask questions about NDA protected topics connected with MIFARE DesFire?
Thank you in advance!
Artem
373 次查看
EduardoZamora
I just sent you a private community message.
Eduardo.
