Hello, NXP experts
My phone act as STA, and i.MX8M Plus EVK board with PCIE8997 act as AP.
My phone can't connect to i.MX8M Plus EVK board with WPA3 SEA AP mode,but success connect to i.MX8M Plus EVK board with WPA3 SAE transition AP mode.
And my phone can success connect to other wireless routers with WPA3 SEA AP mode.
I refer to the steps in chapter 2.4.3 WPA3 security of UM11940.pdf to config WPA3 SEA AP mode.
System version info of i.MX8M Plus EVK:
root@imx8mpevk:~# uname -a
Linux imx8mpevk 5.4.70-2.3.2+g5f2220e87dd8 #1 SMP PREEMPT Fri Apr 2 15:53:04 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
[ 0.000000] Linux version 5.4.70-2.3.2+g5f2220e87dd8 (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Fri Apr 2
[ 0.000000] Machine model: NXP i.MX8MPlus EVK board
Is there any things missing in chapter 2.4.3 WPA3 security of UM11940.pdf ?
Can someone check it for me?
Could you please help me with more information of the document you are using ? I do not seem to locate the document you are using as a base.
If the document is under NDA , please send me the link through a message direct here so I can try to duplicate the issue on my side.
Estephania
Hello, @estephania_mart
Sorry for my delay because of my holidays.
I think you can reproduce WPA3 SEA AP mode connect fail on imx8m plus EVK board when following chapter 2.4.3 WPA3 security of UM11940.pdf
Could you please help me confirm you are using the latest release available in this link for your device ?
Estephania
Yes, @estephania_mart
I download the imx8m plus EVK image form https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
you can check it for me.
Could you please help me sharing the logs and your configuration file ?
Hello,@estephania_mart
Any suggestion?
Thanks for your continued follow up.
Attached is my logs, included all command and config files.
After doing all steps in my logs, my Phone can found PCIE8997 WPA3 SEA AP (named NXP_Demo), but i can't successfully connect to this AP with error "Denied access to network. connection failed". see below:
But my phone can successfully connect to other wireless routers with WPA3 SEA AP mode setuped.
