Hello
We are facing some problem flashing the NHS3152. We bought already 2 NHS3152 ADK dev kits and we were able to flash them using flash magic and LPC-Link2 a couple of time.
With the first dev kit we lost the ability to flash it after 2 day. The board does not respond and even the device signature is not able to be retrieved
We tested the LPC-link2 with the cable using a NHS3100 dev kit and it was working ok.
So we bought the second NHS3152 ADK. Unfortunately, the same thing happened. After 3 or 4 flashing the device is not responding.
The code that we are trying to develop is just using the ADC in continuous mode based on the NHS31xx SW API – Modules – Drivers – ADCDAC – Example 2
Any suggestion?
Thanks in advance
Thank you very much for using our products, I'm very sorry that your development board is causing you this issue.
Do you happen to have a log of the errors that the tool is through while trying to flash the IC?
This will help us for providing a recommendation or, at least giving us an idea of what could be happening.
