I am verifying the 29D5 AES encryption problem. The results are somewhat different from those in the manual. Is it a problem with the software parameter settings?
Solved! Go to Solution.
Hope you are doing well. Sorry for the inconvenience this might cause you but as the information of this product it's under NDA (Non-Disclosure Agreement) the information it's not public, this is not a secure channel to share any information of this device and I do not have the data as well for the same reason.
For more information about the chip could you please contact one of our distributors available in the Distributor Network|NXP? Or if you have a direct contact who helped you with information about this product in a first place, please communicate with him/her.
Ricardo
Ricardo
