Making a PICO-PI-IMX7d Get Wireless Access...
1,605 次查看
silver2row
I used a Debian image I found here: PICO-PI-IMX7 - Linux on ARM - eewiki .
Now, I also started some chatting about this issue w/ the PIC-PI-IMX7 board and configuring WiFi at: RE: PICO-PI-IMX7 and Siging In/Um? - Linux on ARM - Engineering and Component Solution Forum- TechFo... .
I have tried many different things.
  •  I set up and reset up the image either w/ Debian or Ubuntu.
  •  I tried many different downloads for WiFi connectivity for my specific WiFi chip.
  •  I even erased the entire image many times and entered u-boot to make my WiFi chip work.
I am actually out of ideas. I found many resources online for this specific chip but the WiFi chip does not work. Does anyone have any ideas as to where I should place some files and reboot the board so that the WiFi chip works?
Seth
P.S. My WiFi chip on the PICO-PI-IMX7 is AP6335.
1,377 次查看
diegoadrian
Unfortunately, the PICO-BOARD is not currently supported by us. You will need to go directly with TechNexion, they will help you for sure.
Nevertheless, I have found the below information. Probably it can help you.
https://github.com/ajaybhatia/Qualcomm-Atheros-QCA9377-Wifi-Linux
Diego.
