We are working on a device to which we would like to add Zigbee connectivity. To avoid redesigning the whole system, we would like to use a dedicated chip as network co-processor / modem, connected to the host over UART. Is there a ready-to-use firmware that we could flash on the KW41Z to do that?
Armel
Could you please check the zb_fsci_black_box example? I believe that would be helpful for you. You can download it from the MCUXpresso Builder.
Estephania
