Intruder Alarm System Application Note JN-AN-1201 Not Working!
1,616 次查看
davidashraf
Hello dears ,
I've been trying ZigBee HA Intruder Alarm System Application Note JN-AN-1201 but it's not working.
I am sure of the connections and everything as I tried other application notes and worked properly.
Any idea about where the problem might be ?
Thanks in advance.
1,342 次查看
limcb
Have you tried uncommenting CFLAGS in the device makefiles then rebuilding ?
It looks like no debug messages are sent on a clean install.
4 回复数
1,342 次查看
limcb
What exactly is not working ? Which part ?
More information please.
What have you tried ? What did you expect ? What happened ?
1,342 次查看
davidashraf
It's not achieving the functionality described in the application note
Not even showing debug messages
1,343 次查看
limcb
1,342 次查看
davidashraf
It worked ..Thanks you!!
