Hi:
We need to use the JN5189 timer to capture the width of the PWM. I saw this API CTIMER_SetupCapture() in the SDK, but there is no driver_examples. I don’t know how to use this function. At the same time, the datasheet does not indicate which PIN can be used to timer capture,and which capture channel corresponds to. Can you tell me?
Solved! Go to Solution.
You can read the CR register.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
The pin description is in chapter 8 of RM. You can refer this link CTIMER to know how to capture.
TIC
Yes, we found the pin description on datasheet later,but I did not find the CTIMER_GetCAPCounter() in the SDK of JN5189
TIC
