We develop Bluetooth power amplifier + dual antenna switch as dual antenna support KW38 BLE chip.
1)How to dynamically select an antenna with high signal strength for Bluetooth communication
2) KW38+UWB demo code
would you like kindly help to share the related demo code or your comments, thanks.
Best regards.
Guofred
Solved! Go to Solution.
Hello Guofred,
Hope you are doing well. I apologize for the inconvenience, but the UWB products are under NDA. Could you please contact your DBM for more information about the available resources?
If you are interested in one of the Development Kits or Modules (UWB Developer Resources) you would need to go directly with the Module Maker to know the process and the support that they can provide you.
Ricardo
Hello Guofred,
Ricardo
