I send no-aps-ack package, like 'eCLD_IASZoneUpdateZoneStatus' (defined CLD_IASZONE_BOUND_TX_WITH_APS_ACK_DISABLED).
but i need get next-hop MAC-Layer ACK to confirm it's parent node is received this package.
i do not found any callback event in 'ZPS_teAfEventType'.
how to confirm MAC-Layer ACK?
Thanks!
Hello?
Can you give me some advice?
Hi Teddy,
What are the Application note and the version that you are working on?
Mario
Hi Mario,
Thanks for your reply!
sorry, I don't understand the mean of "Application note and the version"
My product is a battery sleepping device(a sensor), base on ZHA1.2 and JN-SW-4168v1620.
when it send a no-aps-ack command(like report, or IAS Status Change Notification, etc), it's parent node will response mac-layer ack, I want to check it. if no response, the sensor need do re-send command, or send beacon request to searching the new parent node.
but I don't known how to check mac-layer ack.
Hi Teddy,
You are working on the Home Automation, so did you take as a reference an Application note ?
Mario
