CLRC663 plus Family includes SLRC610 plus, MFRC630 plus, MFRC631 plus, CLRC661 plus and CLRC663 plus.
And the Development boards of them is CLEV6630B that is CLRC663 plus NFC Frontend Development Board.
We are planning to apply MRFC630 plus for our NFC Reader.
I wonder how we can use CLEV6630B for evaluation MFRC630 plus.
Does NXP install MFRC630 plus on the CLEV6630B instead of CLRC663 if we request it when we order the CLEV6630B for MFRC630 plus?
Thank you.
Andy
I appreciate your interest in our products.
Please let me know if I understand correctly. You are interested in using MFRC630 in your reader is this correct?
Our Evaluation board is based on the CLRC663 puls IC. This IC allows reading any MIFARE, ICODE, or NFC PICC (card or tag).
The typical workflow for development is to develop your application using the CLRC663 Evaluation board with the use of the NFC Reader Library. Our different versions of ICs (MFRC6xx, SLRC6xx) are ordered as a specific part number in the Buy/Parametric option.
The IC package is the same, but the technology reading is limited depending on the chosen option.
Hi Fabian,
Thanks for your reply
Please check my comments under your answer.
[Andy] Yes, I am
[Andy] You meant that we can evaluate MFRC630 through modification of NFC Reader Library on CLEV6630B which is based on the CLRC663 plus IC. Right?
Thank you.
Andy
