Hello All,
I want to reach out to you with for a very specific query around the NXP FRDM-KW41Z platform Bluetooth Host interface
Requirement Overview
What we tried so far
Problem statement
Queries
Thank you.
Dhruv Shah
Yes, it can be used like that.
There is some documentation available in the SDK, but your problems seem to be related to the Linux interface as I was able to run the commands while using the TestTool. I believe this thread can help you:
FRDM-KW40Z Bluetooth LE Controller Usage with the Linux hcitool
Could you please check it and let me know if that worked for you?
Estephania
Hello All,
I'm also facing same issue.
Bluetooth NCP (network coprocessor) over HCI interface is done.
But when i'm trying to connect end device kw41z(i have flashed ble blood sensor example), its getting connected and immediately its disconnecting.
My requirement: From end device(kw41z has connected sensors) want to send sensor data to ble client connected to host. If u have any documents related to plz share me.
Thanks for any help.
Ramya
