There is no problem in commissioning the end node, however there is trouble in making the end node online. Even after repeatedly trying. Even after pressing the SW3 switch, as mentioned.
I think the software might be corrupt, please share the binary file for KRDM-KW41Z.
Could you please post your question in the following community regarding the gateway?
Estephania
