FRDM-KW38 Linkserver program issue
1,078 次查看
Adam_Ho
I am using FRDM-KW38,
MCUXpresso IDE v11.8.0.
Press reset button before connected USB port to PC.
After connected to PC, KW38 is in "DAPLINKBOOT",
Paste download file.bin from "https://www.nxp.com/design/design-center/software/sensor-toolbox/opensda-serial-and-debug-adapter:OP..."
Now, I Debug with LinkServer probes,
The window always show "SWD Configuration" 0 available SWD Devices detected.
Connect a device and try again.
Please help me to debug kw38.
Thanks.
12 回复数
1,055 次查看
Adam_Ho
Hi Ricardo,
Is "Delete launch configurations"  mean "clean up debug"?
I have tried, but still not work.
The last SDK example is "frdmkw38_adv_ext_peripheral_bm".
BR,
Adam
1,038 次查看
Ricardo_Zamora
Hi Adam,
Please delete these files:
Are you able to flash any other SDK example?
Please let me know your findings.
Ricardo
1,014 次查看
Adam_Ho
Hi Ricardo,
1. I have deleted these file and "Debug using LinkServer probes".
2. The same error occured.
Do you have any other idea?
BR,
Adam.
982 次查看
Ricardo_Zamora
Hello Adam,
Your FRDM might be in Low Power mode. Could you try to do a mass-erase? By using an "unlock kinetis" command in J-Link Commander, or a mass erase command through MCUXpresso, which works as well.
And the Low-Power mode can be disabled by setting the following macro (in the app_preinclude.h header file) to a 0, like so:
/* Enable/Disable PowerDown functionality in PwrLib */
#define cPWR_UsePowerDownMode           0‍‍‍‍
If this is not working, I would try with an external debugger.
Hope this helps.
Ricardo
964 次查看
Adam_Ho
Hi Ricardo,
I use MCUXpresso to do mass erase.
but there is "Target Connection Fail" show in console log. 
 I attach the erase log on below.
Could you find any clue on development board?
Thanks for support.
BR,
Adam
808 次查看
Ricardo_Zamora
Hi Adam,
Could you please try using Jlink?
If not, I would recommend checking with an external debugger.
Ricardo
644 次查看
Adam_Ho
Hi Ricardo,
I try program with J-Link.
But it still not work.
I leave the  program error log as below.
Do you have any idea?
Thanks.
Adam
162 次查看
LISI1
hi
Have you solved the problem and can you share it? I had the same problem
thanks
153 次查看
Adam_Ho
Hi @LISI1 ,
Sorry, This issue isn't solved.
Thanks.
149 次查看
LISI1
Well, thank you
1,064 次查看
Ricardo_Zamora
Hope you are doing well. Could you please try deleting the launch configurations of the project?
Which was the last SDK example that was running on the board?
Ricardo
1,043 次查看
Adam_Ho
Hi Ricardo,
BR,
Adam
