Does KW0x (or other NXP solution) suports Sub-1GHz 6LoWPAN?
1,074件の閲覧回数
sreten_jovicic
I am currently doing research for our new project - IoT alarm system for smart home.
One of requirements is Sub-1GHz wireless communication between sensor nodes and gateway (Mash and Star topology). I can see that you have Sub-1GHz Transceiver and SoC solutions.
My question: "Does KW0x (or other NXP solution) support 6LoWPAN Sub-1GHz ?"
Thanks in advance.
ラベル(2)
2 返答(返信)
907件の閲覧回数
estephania_mart
The KW01 supports Sub-GHz but not the 6LoWPAN, we do not have a solution with support for both 6LoWPAN and Sub-1GHz.
By any chance have you checked the Thread solutions? You might find those also interesting for the design of an alarm system, there is even one reference design for that application.
Estephania
907件の閲覧回数
sreten_jovicic
Thank you Estephania for quick response.
