I have looked at a few of the example projects for Thread (hybrid ble thread router, low power end device). The source folder includes a config.h file that appears to set a bunch of defines for configuring the different options for the code, but I don't see anywhere where config.h get included in the project. Am I missing something? Do modifying these defines change the device behavior in any way? thread
Solved! Go to Solution.
I found the answer myself. It is included at build time using -imacros "<path>/config.h"
