I'm using CLRC663EVK and SLIX 2 Tags.
I'm only able to detect UID.
In order to read and write on to the EEPROM, I'm getting a data exchange error. So I think i need to set the privacy password.
In order to set the privacy password, I've to get the RandomNumber. How to get the RandomNumber through Cockpit tool?
To write on to the tags after getting Random number, Where should we specify the block data to be written? In the TX data without flags where should I specifiy the Block and data?
I believe this question has been solved in the internal case you summited.
Jonathan
